Torque arm relocation crossmember
FYI, I have one of the earlier UMI models that doesn't have any TA adjustment.
I posted a link below to the UMI kit for your vehicle. If you have any questions I would be glad to help.
98-02 F-Body Torque Arm Relocation Kit, M6
Happy New Year!
Ryan
I hope this helps,
Ryan
I hope this helps,
Ryan
With the horror stories of poly trans mounts, I wont touch one. I know people who have them and their car rides fine. But I have heard of local people with awful vibrations as well. What I was saying is, what if you ran the relo crossmember but with a rubber torque arm bushing instead of the supplied poly. I mean this is your ONLY isolation point from the body since you have eliminated the stock trans mount from the equation. I will need to put more miles on mine before I decide how bad or good this set-up is. With my car, if I have anything out of whack, I get a vibe upon initial power apply during acceleration. Often times this comes with removing the torque arm and replacing it. I can usually loosen the torque arm with the suspension loaded, it will settle into place better, retighten and everything is back smooth again. I am currently having this same vibration again, but haven't tried the loosen/retighten trick yet. We will see if that helps. I dont know if all cars are this picky about driveline angles or if its only some.
May be the the front TA poly bushing (w/round hole) has already began to cold flow causing a slight amount of slack between it and the TA nose, causing the vibration?
