BMR Springs and Bilstein HD Shocks installed
Got some work done to the car this month.
BMR 1.25" Lowering Springs
Bilstein HD Shocks
Nitto 555's, 275/40/17 all 4 corners
OLD ride height with Stock Set Up
NEW ride height with the listed parts
We are getting a knock comming from the front passenger shock tower while hitting even mild bumps. Everything was installed back together nice and tight. After the install we pulled the wheel back off and double checked everything and found nothing loose. Any idea why just the passenger side would be doing this?
Bilstein HD Shocks
check the motor mount, with the decarbons didnt really notice it, but with the stiffer konis i kept on getting a weird clunking sound. just an idea, either that or its the top nut not tightened down enough
LS1TECH Sponsor
It's a shock mount guys, not a strut mount. 4th gen's don't use struts......
__________________
I will definitely be looking into this in the spring, I have had a nasty noise going over bumps for a couple years now and found nothing out of the ordinary. Thanks for bringing it up.
