e brake help:bang:
Hi,pull rear wheels and check adjustment........run out until slight drag
back off/clearance should be .026. If working properly re-install wheels
and lower vehicle..have a blessed day........jim
You'll need to take the rear brakes off, so you can remove the rotor to get to the adjustment wheels on each side. You adjust, put the rotor back on, and then pull the actuating lever at the back of the brake plate, which the cable adjusts to. If the lever moves 3mm, you are good. If not, remove the rotor, and repeat.
Once the brakes are properly adjusted on each side, the lever should only come up 3-5 clicks.
Brian,i know you are frustrated! However, the problem can be resolved with a complete check of your system. You are missing an issue! Have another person take a peak and see if they find your problem..keep your chin up and press on until you resolve brake issue. I HOPE THESE DOWNLOADS HELP YOU.THEY ARE COURTESY CHILTON....HAVE A BLESSED DAY..JIM
- The star wheel mechanism is gummed up and when you turn the wheel, it bounces back really quickly and you don't notice it. (If you mark the wheel before you turn it, you can confirm.)
- You are turning the star wheel the wrong way.
- The rectangular plate that holds the rubber boot and lever in the back of the backing plate is loose or bent, so the lever doesn't engage the pins.
- You only adjusted one side. You will have to adjust both sides independently before you will see any difference in the holding of the brakes or at the handle.
When you made the adjustments, did you confirm the play at the lever behind the backing plate?
