short vs long torque arm
Pros and Cons?
I always thought that I would want a tunnel mounted torque arm, but not until after I installed TSP 3" true duals dumped.
Is the body mounted torque arm worth redoing my exhuast when it is a nice weather, weekend warrior car, or would the replacement torque arm with the tranny mounted relocation kit suffice?
Opinions please.
Car is a 370 (H. Comp, N/A), t-56 with Monster level 3, s60 with 4.11's.
So far for suspension I have adj. Chromoly LCA's with the roto-joints, LCA relocation brackets, QA1's w/300# springs on the front, ADJ PHB and cut rear springs with hose mod.
Getting drag radials very soon as well.
Opinions please.
i just ran in to the same problem with my car when i installed my tsp true dual, i switched out my tunnel mount tq arm with a bmr full length and it works well. now i just have to get a relocation bracket and be set.
LS1Tech Premium Sponsor
I would use our BMR full length adjustable torque arm (TA001) along with a BMR torque arm relocation transmission crossmember (TCC006). These parts will fit with the exhaust setup you are currently running and will work well for the kind of driving you are doing with the car.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
I hope you don't mind me posting this. I like to see notes like this as guidance ... !!!!
https://ls1tech.com/forums/attachmen...00917-2127.jpg and the second of course this is with there whole rear and stuff but you get the idea. It mite be different I dont know, dont worry about the mess under there is clean now https://ls1tech.com/forums/attachmen...00917-2129.jpg
I did some research before I chose to do the full length tq arm w/ relocation. From what I was advised unless you plan on running deep into the 7's in the 1/4 then a relocated stock length tq are is fine. Some say that the shorter one's work better, and hit the tires harder, but there are quite a crew of people running in the 8's that have no problem with them. And the short style that clear the duals have bad ground clearance....Again thats what my conclusion was. I ordered the long one, and its a freaking beast. I cannot believe how heavy duty that thing was.....GL man
I have great ground clearance with my TSP duals, Its all about who installs them and takes the time to tuck them up properly. Short arm hits tires hard, gets car to 60ft better/better ET that is the way I look at it. Either way they all work in the same fashion its up to the owner in knowing what the want out of the car. Of course this is just my opinion.
"NOTE: This torque arm has been safely tested to 11.0 in the quarter mile and is not recommended beyond. These restrictions are due to the limitations of the transmission tailshaft housing mount, not the torque arm. If your car exceeds these levels of performance, the BMR Trak PakŠ or Xtreme Duty torque arm(below) is recommended to remove the stress from the transmission tailshaft."
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
