Need help with a broken K-member bolt
So as im finishing up my BMP K-member install, I went over the 6 K-member bolts one last time just to be sure they were all snug. I ended up breaking the middle passenger side bolt right in half. FML!... So now im trying to figure out how to go about pulling the metal sliding plate (not sure what its called) that the bolt threads into, out of the car. Does anyone know what this plate is and how it comes out?
Any help would be GREATLY appreciated.
Thanks in advance
-Rob
Thanks in advance
-Rob
No, its up in the body of the car, it looks like that metal plate that the bolt threads up into may come out the side though. I just dont know how to go about getting it out.
You make a good point there. I didnt even think of it like that. I was avoiding drilling it out for fear it be a pain in the @$$ due to all the tension and the bit getting broken off in the bolt. It should be fairly easy though. thanks for your reply
LS1Tech Premium Sponsor
Drill it out and use an EZ out, also a little heat from a torch may help get her out. Honestly the bolt is so big that it shouldn't be that much of a pain to do.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
You can buy a graded bolt from Home Depot or Lowes. Make sure its a 10.9 or whatever the highest grade is they sell. Take a matching bolt from the other side so you get the right one.
