need ideas??
What's your budget? I'm assuming it's a street car?
All parts priced at O'Rielly's:
Moog Front lower control arm bushing kit (2) required $52 each
Moog Front upper control arm bushing kit (2) required $25 each
Moog Front lower ball joint kit (2) required $35 each
Moog upper ball joint kit (2) required $69 each
That will get your front end bushings/ball joints completely replaced. Look into the Bilstein HD shocks for replacements, they can be had for right around $400+shipping for a full set. And if your wanting new springs and a nice drop get the Strano Springs.
For the rear I'm a fan of at least getting adjustable LCA's & adjustable panhard. If you have the money get a adjustable torque arm as well. Then you can fully dial in your suspension. For a daily driver thats not getting tracked alot, your stock torque arm will be just fine though IMO, especially if you dont have the extra cash for a aftermarket torque arm.. If the car will be raced & you upgrade the suspension to aid in that, you better be looking into upgrading the rear end too cause it'll be next to go most likely.
Do you have any other suspension mods?
Depending on the springs you have, swapping out the shocks and the springs could really improve the way your car functions, both in handling and launching. Adding in a few other parts could improve things further.
BTW, what all do you have on your car? Vague posts are hard to answer well....
