I need help with torque arm install...
This is on my 99 TA with an M6....what did you guys remove to make it easier getting the old torque arm out? Cause once i get that out i can get the new in.
do i have to drop the cross member?
can i do all this with the exhaust in tacked.
More or less i need to know what you guys did to get the transmission bushing unbolted and out so i can get the BMR bushing in....
removing the torque arm from my 87 iroc was and is a pain to get it out and in...
and looking at the 4th gen underbody...it looks like it will be a pain too
rear is already jacked up and on jack stands with the rear hanging....the 2 rear bolt are nothing to get out...its the front
help me out.
Hi,i would place a small jack with a piece of 2x4 on top to support transmission. Remove crossmember support. Lower jack slightly to gain access to bolts (torque arm). Remove them..... A 3/8 drive with a universal and long extension will allow you to work with exhaust intact. A box end rachet helps on the top bolt.lower rear after removing two nut on rear bolts. This will give you the top clearance to remove these bolts/watch your head and hands to avoid injury. The torque arm can be awkward due to the length. I usuall use my feet and knees if no one is around. Make sure car is supported safely on approved jack stands/ramps. Rear must be supported by jack stands on rear body supports to allow lowering. You will need to remove shock bottom nut to allow the drop needed..........good luck and have a blessed week..captain jim
do i have to take the whole bushing housing off? or just open it and take the old out and replace with the bmr?
everything else i know how to take care of....ive done it 1000 times on my iroc I just needed to know how to gain access on these 4th gens.
ignore my stock ex manifolds and Y....that will be replaced soon as the camaro sells....lol
Getting that bolt back in can be a dog. The angle has to be just right to let the clamshell close all the way and line up. I ended up supporting the arm with bungee cords to give a bit of play. Once that top bolt is in loosely, use your main jack to lift the pumpkin to allow the bracket to slide in place, then you'll probably have to tweak the pumpkin height a couple of time to get bolt holes to line up.
BobP
Hi,sorry for the delay........i use a drill to remove the rivets on clamshell as mentioned above. Then tap with a punch to remove. Option 2 grinder on one side and then use punch to remove..careful with grinding due to bracket interlock.
Bushing must be installed correctly/use supplied lube/wrench size 15mm/22mm rear of brace.
HAVE A BLESSED EVENING.....JIM
pulled the clamshell and drilled out the rivets..cleaned and degreased everything and put it all back together and torqued it down.
thanks for the help guys!!!
has anyone had trouble turning the adjuster bolt? I cant budge it!
Ive PB blasted it and everything.
Could it be in a bind somehow? Ive got positive 2 on the driveshaft and negative 2 on the torque arm so im at "zero" they are both sitting pretty straight.....could that be why the adjuster wont move?
any idea? and something i can try?
thanks!
thanks guys for checkin in.
