BMR SFC's loose LCA bolt
I can't get the LCA SFC bolt to stay tight. I try to tighten it, but I can't crank on it too much and it just comes loose again. Any ideas? Does the suspension have to be loaded to tighten it? Can I get a mechanic to hit it with an airgun on the lift? I get this clunking noise from the rear and the car doesn't handle like it should.
Use red Locktite on the threads. Here's a picture of a boxed end wrench I did, on the right is a crows foot wrench you can also use with a torque wrench.
Al
Al
thanks for the replies, they clunked from the moment I got on the highway after they were installed, they were never tightened properly I suppose. I'm gonna get the rear wheels up on some ramps and crank on it and see if that works. I think the bolts fine, I didn't have much room under the car to tighten it up and I could never tighten it real good.
