need help picking out new shocks..
Old 03-20-2011, 10:50 PM
zac50's Avatar
Default need help picking out new shocks..
so im most likely going to be purchasing some strano springs for my ride and i was going to grab a new set of shocks while im at it and was needing help gettin the best bang for my buck! i have heard people talk about several like koni and blistein but im unfamiliar with any of them and need some help.. Thanks guys
Old 03-20-2011, 11:14 PM
a-low's Avatar
I was just telling a guy about the stranos springs sfc and konis i just did on my car
its no hype this things are amazing! Sure theyre pricey but worth it and the konis
have a lifetime warranty. Now the car is stiffer im taking turns quicker and couldnt
be happier.
Old 03-21-2011, 06:39 AM
Cheap Guy's Avatar
I had KYB AGX shocks on my previous car and they were much better than the stock shocks. I just put a pair of Bilsteins on the rear of my current car and I haven't driven it hard yet and I still need to do the front shocks, but they are noticeably higher in quality than the KYB shocks. They are easier to install due to the allen head in the top mount that makes it easier to tighten down the top nut.
Old 03-21-2011, 05:09 PM
leadfoot4's Avatar
Konis if the budget will stand them, Bilsteins if funds are a little tight....
Old 03-21-2011, 05:29 PM
alone_and_insane's Avatar
I've heard very good reviews on SLP Bilsteins (Strano has those too), I plan on putting them on my car.
Old 03-21-2011, 06:02 PM
justin hover's Avatar
I just did my blistens last week from strano...perfect performance aftermarket shock and their on sale...
You should call Sam Strano like I did..he'll do you right
You want konis if you plan on lowering from my understanding..
Blistens seem like the way to go
Old 03-21-2011, 07:14 PM
walter1234's Avatar
If you’re budget conscience like me, I highly recommend SLP Blistens. I replaced both the front and rear shocks with stock Z28 springs, and WOW what a difference it made. The car feels a lot more stable at speed and going over residential road hump is no longer an adventure for me. I brought my at the WS6 store.
Old 03-21-2011, 07:38 PM
jim ravencraft's Avatar
Hi,
check with some of our vendors who have much expertise on your needs. They can help save you money and grief..have a blessed week.....jim
Old 03-22-2011, 09:01 AM
zac50's Avatar
well i have heard mixed reviews on the blisteins and a couple others, so im thinking im just gonna save the money and do it right with the strano/koni setup
Old 03-22-2011, 10:54 AM
konis are too expensive unless your going to lower...blisteins are perfect..
Old 03-22-2011, 11:04 AM
LS1TECH Sponsor
Sam Strano's Avatar
I have to disagree with the notion that Koni's are overkill unless you lower the car. Yes, lowering a car works the shock harder and Koni's have more ability to deal with that over the long term. But shocks also control mass, and that mass is there regardless of the height. I have two stock height cars, on Koni's. There is still a difference.
It's a bit basic to say if you aren't lowered then Bilstein's are fine. Kind of like saying if you engine is stock, headers are a waste. Not true, sure headers help an engine that breathes better, breathe better--but they help a stock engine too.
__________________
Old 03-22-2011, 11:41 AM
zac50's Avatar
i was wanting the lowered look that the strano/koni setup gives.. im not sure how the strano/blistein look looks... and also like i said i have heard mixed reviews on the blisteins...
Old 03-22-2011, 11:44 AM
LS1TECH Sponsor
Sam Strano's Avatar
The height is set by the springs, the look won't be different between Bilstein and Koni if the Koni's are set on the upper spring perch as they should be with lowering springs.
__________________
Old 03-22-2011, 12:12 PM
zac50's Avatar
oh ok well im still leaning toward the koni's because of the reviews i have read...
Old 03-22-2011, 12:26 PM
LS1TECH Sponsor
Sam Strano's Avatar
Koni's are definitely the shocks with more control....
__________________
Old 03-22-2011, 12:34 PM
projektnitemare13's Avatar
I absolutely love mine, I run Strano springs, and Koni DAs up front (got em for next to nothing) and SAs out back. Great for my car which is a dd that sees some drag, and road course time. Sams stuff kicks many forms of ***. can't go wrong.
Old 03-22-2011, 12:48 PM
99FormulaM6r's Avatar
I run my car with Koni's and stock springs, I love it. You get the handling, stability, adjustability (which I've used a lot to dial in the ride that's perfect for me, and finally found it), and control of the Koni's with the comfort of the stock springs....Strano gets my vote also!
Old 03-22-2011, 09:03 PM
bwilde86's Avatar
What's the difference between the bilstein hd and the slp bilstein shocks?
Old 03-22-2011, 11:05 PM
Almost nothing now. Buy whatever's cheaper.
Old 03-23-2011, 09:59 AM
LS1TECH Sponsor
Sam Strano's Avatar
Used to be quite different, today that's not the case. Which is why I started carrying SLP's in stock a lot more. Have an order of 15 sets on the way as I type this.
__________________
Quick Reply: need help picking out new shocks..
