Spring settle question Strano's
I just want to make sure its the springs and nothing else.
The car itself appears to sit level, front to back, with the ground; which is what I think it's supposed to do. I only have maybe 20 miles on the springs so I'll see if it settles over time.
I added new poly swaybar bushings and end links at the same time, keeping the stock SS sway bars. The car is planted on the road now. I mean it's very stable at speed and VERY responsive with almost no body roll (just highway speeds with a little playing, I haven't beat on it yet) in turns. It's a little rougher on crappy roads but that's to be expected and nothing unbearable. I NEED to get v6/Z28 bump stops in the rear because mine are rotted and you will be on them a lot on these Louisiana roads.
I'm ok with the look and happy with the preformance. If the fronts settle after a couple hundred miles/few months I'll be very happy with the look. Worst case adding heater hose to the rear is easy and will even it out
It's because the front wheel well is 1/2" taller than the back, measured as Sam Strano said from the line of the rocker panels.
People a freaking out about nothing.
The simple fact that you see folks reporting some variance isn't surprising. I always suggest folks look at pics of various cars to get a sense of what they'll get. A picture is worth 1000 words. And I'm sure you've noticed how differently some stock cars sit vs. others. Some sit very high, some lower, some high in the rear, some high in the front... See the pattern? Also there is personal opinion. What someone things looks great, someone else thinks isn't low enough (or is too low).
