Wheel hop
Old 04-24-2011, 02:25 PM
x42bnx's Avatar
Default Wheel hop
I have Subframe connectors, adj. pan hard, bmr springs, bilstien hd shocks and C5's with 275 Daytonas. They are semi sticky and under any burnout or hard acceleration I get massive wheel hop.
Lower control arms maybe?
Old 04-24-2011, 03:15 PM
ULTIMATEORANGESS's Avatar
Smile
a stickier tire id try first.
Old 04-24-2011, 03:26 PM
SSmoked1's Avatar
I would get some LCA relocation brackets first. They are cheaper then experimenting with tires. If not cure it will help a lot.
Old 04-24-2011, 09:18 PM
skopers3's Avatar
Torque arm ended my wheel hop like nothing else I've bought.
Old 04-25-2011, 02:08 AM
x42bnx's Avatar
I have the stock torque arm, an adjustable maybe?
Old 04-25-2011, 03:55 AM
DVS99TRANS's Avatar
I would say the LCAs also. Wheelhop seemed to go away for me with them. But haven't seen anything since I got my adjustable torque arm.
But seeing that your lowered means you need LCA relocation brackets for sure like mentioned above. That should help clear up a little of wheel hop.
Old 04-25-2011, 08:00 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
I would do a set of BMR lower control and BMR lower control arm relocation brackets. These two thing should clear up any wheel hop you have. If you decide you need any suspension parts give me a call and I will work up a deal for you.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 04-25-2011, 10:07 AM
x42bnx's Avatar
Thanks guys, BMR I'll give you a call as soon as I'm ready to order. This wheel hop is killing my rear end.
Old 04-25-2011, 10:23 AM
BMR Sales2's Avatar
Wheel hop can easily wreck a rear end. I look forward to being able to help you out.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 04-25-2011, 12:59 PM
SVThuh's Avatar
I have a set of LCA's new in the box for sale.. I just sent you a PM.
Old 04-25-2011, 07:14 PM
bigj2717's Avatar
A torque arm got rid of all my wheel hop
Old 04-25-2011, 11:10 PM
highway21's Avatar
most likely you LCA's.. if there the originals i would get some umi or bmr's and some relocation brackets.. if your on a budget just replace the stock bushings (stock ones are crap and are not even a solid bushing) in the LCA's.. even on street tires you shouldn't have wheel hop, tires should just spin freely..
Quick Reply: Wheel hop
