Wheel Hop
Old 05-02-2011, 09:14 PM
TORCHD 02 TA's Avatar
Default Wheel Hop
What creates wheel hop? It seems as of late, my wheel hop has gotten a lot worse.. It sucks lol.. Feels like I'm gonna break my rear end... Sooner, rather than later
Old 05-02-2011, 09:57 PM
Vexzer's Avatar
My only experience with rear wheel hop on these cars was at the track. I maybe launched too soft. Felt like I broke the driveshaft! As I got better launching it never reappeared. Later in the shop I found I had bent the aftermarket studs! (all was torqued to #85). This is on a Strange 12-bolt with 3:90 ratio.
Maybe your pinion angle somehow wrong? Loose control arm? Control arm relocation brackets if you are lowered? Maybe it's really clutch chatter (check the patch on a clean surface)? Maybe the torque arm is loose?reaching for straws here. Let me know what you find.
Old 05-02-2011, 10:01 PM
Car is STOCK as far as suspension goes.. Doubt anything is loose.. But doesn't hurt to check
Old 05-02-2011, 10:05 PM
AndyIsLost's Avatar
Control arm relocation brackets are great for reducing wheelhop. I didn't get much hop on the track to begin with but it was BAD on the street, and they helped me a lot on both, more on the street and that's all I have suspension wise.
Old 05-02-2011, 10:11 PM
I never got wheel hop at the track either.. Only on the street.. And its terrible
I may have to get some LCAs
Old 05-02-2011, 10:13 PM
Iwannagofast!'s Avatar
One of my factory LCA's was bent. Check those out.
Upgrading to an aftermarket torque arm or getting some new LCA's wouldn't hurt either.
Old 05-02-2011, 10:17 PM
Vexzer's Avatar
And this may seem like a lame reply, but experiment with air pressures a little. It can make a difference -especially as the tires change due to wear.
Old 05-02-2011, 10:22 PM
I do want to get an adj T/A and adj LCAs
I usually run my tires at 34 psi... And my rear end is STOCK like i said. nothing has ever been removed for my car...
Old 05-02-2011, 11:22 PM
HWI
HWI's Avatar
LCA's w/ relocation brackets fixed my wheelhop.
Old 05-03-2011, 10:50 AM
rabbit320's Avatar
if you didnt use to get the hop, then something has aged... id check bushings and shocks... the later being the key. but from yr mods you do have some power, time to control it. the relo brackets will help more than lca's, id do those first, and id recommend a torque arm, but not for the track as you will snap something i bet...
Old 05-03-2011, 02:53 PM
mad_steve's Avatar
Lower control arm relocation brackets usually eliminate wheel hop issues. An easy way to check if you need them : If your LCA's have a downhill angle toward the front of the car or are parallel to the ground, then you'll need the LCA relocates. If your LCAs angle uphill toward the front of the car, then your wheel hop issue is due to something else in your suspension. I'd check the shocks and LCA bushings, to be on the safe side.
Old 05-03-2011, 03:37 PM
SVThuh's Avatar
Adjustable LCA's are pointless.. Get them non-adjustable and never have to worry about them being setup wrong.. The adjustables are set to stock length anyways.. Save your money..
Hell, buy my Hotchkis LCA's.. $200 shipped to your door. BNIB!
Old 05-03-2011, 04:55 PM
Detoxx03's Avatar
LCA's and new bushing fixed mine
Old 05-04-2011, 06:05 PM
greatskiiiier's Avatar
when I put on my LCAs my wheel hop was reduced to almost 0... now with bald tires, LCAs, sway bar, and tq arm, its coming back about 1/4 of the time that the tires break loose
Hope that helps
Old 05-06-2011, 09:24 AM
1lejohn's Avatar
Not true if and when you run slicks you will need to be able to adjust the axel's center so that you can fit them. You still might have to cut some of the lower fender away.
Wheel hpo is caused by the tire loading and unloading due to gaining and then lossing traction. A good set of drag radials or slicks will fix it as well as a built suspension.
Old 05-06-2011, 11:28 AM
Chubbz155's Avatar
I had the same problem last year! I just put on a UMI T/A with Relocation mount and it fixed my problem. I had all UMI suspension parts on the car except the Torque Arm. The stock torque arms are cheap and the flex alot under load. I would defintaly try a T/A!!
Here is a broke stock T/A. https://ls1tech.com/forums/suspensio...orque-arm.html
Old 05-06-2011, 05:13 PM
Tommyv8's Avatar
I used to get quite a bit of tire chatter when launching at the track. I got LCAs and a torque arm from BMR (non-adjustable on both) and now it either hooks or just spins smoothly, no wheelhop.
Old 05-07-2011, 12:01 PM
1lejohn's Avatar
The UMI arms work great thats what I have on my car.
Old 05-07-2011, 12:17 PM
justin hover's Avatar
I had shitty wheel hop a last year....I talked to Sam Strano (sponser) he hooked me up with bilstein shocks and poly/roto non-adjustable lcas. Completly got rid of my wheel hop, and tightend up my ride alot...
Quick Reply: Wheel Hop
