UMI STB Fitment Issue
Old 05-22-2011, 02:09 PM
MasterTomos's Avatar
Originally Posted by leadfoot4
NO, it is NOT completely different. The only difference is that the 3 or 4 point STBs also connect to the firewall. This, however, does NOT change the face that the bar has to go over the studs of the upper shock mount....
OK, I'm going to edit this, to avoid what appears to be some confusion. After looking at both BMR and UMI's sites, it appears that they are using "slots" on their STBs, instead of holes. I imagine that they are doing this for ease of installation, however it may allow for some movement or "flexure" at the mounting point of the STB. The LG Motorsports STB that I have has 4 distinct holes in the mounting tabs, and this STB mounts "snugly" over the shock mount studs, therefore it is impossible to install my STB without dropping the shock/spring ***'y.
Apparently, the STB that "mitchntx" either has, or has seen, is constructed the same as mine, therefore his agreement with me, on the mounting procedure....
Every UMI 2 point I have seen has the "slots"...Ive never seen one with holes.
Old 09-28-2011, 02:35 AM
TruBloodTransAm's Avatar
Friend had a similar issue and we jacked up the kmember like suggested by UMI, was able to get it to fit.
Old 09-28-2011, 10:23 AM
Moderator
jimmyblue's Avatar
This is one thing to like about the Hotchkiss STB, it has separate
pedestals and crossbar and you can get the pedestals loosely
installed and canted, get the crossbar in and then dog them down.
Quick Reply: UMI STB Fitment Issue
