I saved a dogs life, but killed a wheel
Hi guys, I missed the dog but nailed the curb in the Camaro last night. I've been reading a lot on here since I got my z28, but haven't registered until today. After I hit the curb I got out and check to see the damage. I hit the front passenger side, and the rear just barely grazed it.
Since this is my first post, my car is a '99 z28 with the stock 16" rims. It's bone stock at the moment. My question is, what typically takes the brunt of the damage in situations like these? I did a drive way alignment to get it close to where it should be until I get new rims/tires, but I can't find anything wrong. Nothing looks off, bent, or broken. Right now after I did my home alignment it tracks right and pulls left.
The worst part is I just did inner/outer tie rods, upper/lower ball joints, sway bar links, rotors and brake pads like 3 days ago, then this happens. I JUST had it aligned two days ago. Such is life I guess...
Any input would be appreciated.
Chris
Chris
Well I just ordered some wheels, and I'm gonna get tires done at Discount. I'm undecided between 555s or nt05s, but that's irrelevant to this discussion i guess. Once i get the wheels in and the tires mounted, I'm going to take it to an alignment shop. I called a local shop and told them what happened and they said they would let me know what, if anything, was messed up when they do the alignment. I do all my work on cars myself, so I hate having to take someone's word on what is wrong with my vehicle.
You're right though, all I can do is hope the shop knows what they are doing and go from there.
Chris
Chris
Also, is the rack and pinion supposed to leak fluid into the sleeves that go over the inner tie rods? I'm not very familiar with rack and pinions, but it doesn't seem like any fluid should escape that ram. When I pulled those sleeves back to get the inner tie rods off, they were full of power steering fluid. That doesn't seem right to me.
Chris
I finally discovered what I did. I moved the castor and camber adjustments on the passenger side when I hit the curb. I could tell the arms moved because the washers for both of those bolts dug metal out of the arms when they moved. It was pretty obvious where they were for the last 10 or so years.
I put a new R&P in (what a pain) before I got it aligned. They couldn't bring the castor completely into alignment, it was a few tenths off. It is pretty good though, so I'm happy.
I'm not sure anyone cares, but I hate unresolved threads!
Chris
Chris
Chris
Chris
You wouldn't like it if you were on the other end of dishonesty. Jeez, I can't believe this guy even posted this.
Chris
