What it'll take to lower my Camaro
Wanting a 1.25-1.5" drop, I have 17" wheel with 315 Nitto with stock suspension. Not wanting to spend a ton, and I don't plan on doing shocks at this time. Not really shooting for a perfectly smooth ride either.
I want to make sure I know and have everything before I attempt to lower it, don't want any surprises.
Seen some 1.5" lowering springs on ebay for around 100 shipped. Any experience with those?
What should I expect to buy to lower the car? Springs, Adjustable Panhard Bar, LCA/Brackets?
I'll be needing an alignment, how much do those usually run?
I'm new to suspension modding so any help would be appreciated. Thanks Guys
I'd use Strano SP141's and a UMI adjustable PHB to center the 315's.
You don't NEED LCA's but they help. Relocation brackets are a medium NEED as you don't want to have the control arms pointing up toward the rear after lowering. Of course you can skip them if you're just daily driving. They're easy to add if traction disappears.
ramey
Strano or BMR springs will get you the height you want. A UMI single adj. panhard bar is a cheap/effective way to center the rear end after lowering. These parts are what I would consider a proper basic lowering.
LS1Tech Premium Sponsor
Avoid springs without a name brand or undisclosed spring specifications. Not all springs are created equal.
A GOOD four wheel alignment should cost between $65-85. Since there is no alignment on the rear of these cars, you can usually get our for $55-75.
- Kevin
Let me know if you have any questions and I'll be happy to answer them for you.
Strano springs are the best. Do not use ebay springs. Replacing the stock shocks with a set of Konis or Bilsteins at the same time would be a good idea. The stock shocks are inadequate for the stock springs much less lowering springs.
No sir. My SS was sold and totaled. My T/A was sold and destroyed by the new owner. I gave my other T/A back to my friend who let me keep it for a year to have some fun with in the magazines.
haha Now I have a GTO only. One of our guys has a WS6 with 18-inch 295 Z06 wheels in the parking lot though.
I'll give you a little tour today, Jon.
- Kevin
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
- Kevin
I urge you to save your pennies and buy shocks. If you lower your car on stock shocks you will hate your life. If shocks aren't in your budget right now, buy all of the other stuff and put it in your closet or something. Then buy shocks when you have the moneys. You will be a lot more satisfied when you have something that looks good and handles good.
Thanks for all the advice guys. I've thought about it some and it would probaby be a good idea to just go ahead and do the shocks now like some of you said. I looked at the Strano SP141 lowering springs with the 1.2" drop. Also looked at the Bilstein Shocks from there, I noticed the SLP shock set was cheaper than the HD set.. What's the difference?
- Kevin
If you are on a budget, do the heater hose mod ($20).
It works on rear of the car only but makes a better appearence.
Changing rear springs are easy , but putting ebay no spec/brand name springs will require you to removing the front shocks, reinstall & alignment.
Most likely you won't be happy visually or ride comfort or HANDLING (biggest reason you want to change from stock suspesion).
IMO
The best way to go about doing your suspension is:
Figure out what size wheel/tire combo you want to use.
THEN choose your shocks/ lowering springs.
Then figure out all the supporting mods like Rear LCA's, PHB, SFCs or BFH to make your tires fit once you are lowered.
IMO
