Quick question please help on konis!!
Is three threads on each of thr front good??
Did you put on the front dust boots ( not mandatory )? Maybe the assembly is still loose. The manual calls for 32 ft/lbs on the top nut with the coil compressed so as to not preload the upper nut ( don't overcompress the coil either ).
I say remove the front wheels and recheck everything you touched. Maybe you left a socket or other tool in there that is flopping around? No shame in going over everything. For safety's sake, double check everything.
Im driving it right now and it is sqeaking in the front
i also replaced the 2 end links for heavy duty ones at auto zone (only 4 bucks each) because i broke them taking them off, i just want to make sure of the squeaking before i drive it anymore to be safe.
Anybody know what could cause this squeaking? Is 1/2" of threads too tight? My torq wrench didnt click at 20 pounds and its as tight as i can get it?
Can Anybody help me out? What can the front squeaking be caused by? Can Anybody tell me how to tighten the top nut??
Front squeaking can be caused by a number of things. Anything that moves. Check it all. If you have old original bushings in your control arms those could be a source for example.
Sway bar end links should be 17 foot pounds.
It's still worth checking the control arm bushings if they are original.
