what to do?
After you take the bump stop extenders out and get the panhard rod adjusted, if you still have some rubbing, it may be as simple as just BFH'ing a few spots to get the clearance you need.
You might also try some adjustable LCAs (lower control arms) for the axle; if the wheels aren't centered, you might be losing some travel before the tires hit metal because they're pushed too far back.
