WS6 w/FE4 rack & pinion ?s
1. the driver side bolt that I plan on cutting off will the orginale bolt (new from dealership) fit upsidedown?
2. I'm thinking it will w/ adding a few spacing washers to keep it off the oil pan?
3.if I'm able to obtain a oem bolt at junk yard are both bolts the exact same size?
4.lastly for right now will I need a fork tool to remove the tierod ends? or are they just beaten down w/ a BFH?
__________________
__________________
Here's some info that I have from replacing my rack over the summer.
https://ls1tech.com/forums/suspensio...l#post16493125
Good luck!
Good luck!
__________________
__________________
2. I don't think spacing was necessary, but I used an allen head bolt I bought at Fastenal.
3. Yes
4. I always just use a BFH. Rented a fork one time, and it seemed like it was going to tear up the boot.
Good luck!
Good luck!
also did you change the tie rod ends when you did the RP swap? if yes did you use the Moog brand?
Thanks
[QUOTE=buellxb12s;16783210]My ss has the fe4 handling code but haven't found solid info of what it consist[/QUOTE
did you see this FE4 code on you door lable? I believe it was in the second row two down from top?
Thanks
I used the allen bolt because that's all Fastenal had in stock that was at least grade 10.9 in the correct length. I already had the sockets for allen bolts, so it didn't matter I changed one of my tie rod ends last year or the year before, don't remember what brand I went with. Helpful hint, before swapping your old rack for a rebuilt one, make sure you took the jam nuts off just in case they didn't give you new ones. Had to turn around and drive right back, doh!
