c6 z06 rear brakes on 4th gen
Im getting ready to attempt the rear swap to the z06 brakes and have the kore3 brackets bolts and lines..wondering if anyone had any tips or suggestions before i start tomorrow.
have you talked about this to anyone with regards to your rear brakes on a 4th gen?
Keep in mind that the front/rear weight ration on a 4th gen is way more front heavy than a C6 Z06, which is why the rear brakes on a 4th gen aren't beefy.
If anything change the front brakes ONLY on your 4th gen unless you are willing to disengage your ABS and also get a brake proportioning valve and do manual adjustments until you get the front/rear brake ratio set the way you want to.
LS1TECH Sponsor
Not a good idea to even try and attempt... if for not other reason the solid axle and the fact the axles float around which will cause issues with hard fixed calipers like those PBR's.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
Well, did you change the master cylinder? Because while you have 4 piston rears now you only had singles to start. If the hydraulics haven't been changed then you just aren't applying much force back there.
And pad knockback is a real thing and when the caliper can't move, but the axle can, it will cause the pistons to be pushed back into the bores under higher loads and give you a very long pedal. This is why you don't see other OEM cars with Brembo front brakes and a solid rear axle using them on the rear (Mustang).
__________________
I'm sure most people aren't going to notice it until they REALLY get on the brakes hard. Street driving doesn't count. When the rear engages hard enough, the brake hop will eventually occur. Especially for people who have a lot of "anti squat" modificaitons like short torque arm, relos in the lower hole, etc.
Just asking but if this was the case, why does Baer Brakes and Wildwood offer a 4 piston fixed caliper kit for the rear?
PewterSS - did you modify the factory backing plate to work with the e brake? i looked at it and doesnt seem to hard to make it work?
No didnt do anything to the master cylinder..jist installed the bracket and everything else and bled the brakes. i have noticed im getting a squeaking sound when cruising and sounds somewhat rough coming to a stop at Times. Everything seemed to have enough clearance.
You have to remove the rear diff cover and axles to put the brackets on...not that bad to do. I have the fronts on now as well which were easier to mount on.
I have to either machine the brackets or calipers as the pins are rubbing the inside of the rotors and wearing a groove on the rear because its not centered on the rotor.
holy thread revival, batman!
reviving old thread to add a quick question, because I may have a line on Z06 rear brakes for very cheap (depends on my mad negotiating skillz). Understanding that my car has:
- Moser bolt-in rear axles (Ford style) in a 8.5" 10 bolt + watts link
- A LS3 dropout being put in soon (tonight, if I get the time)
- serious weight reduction off the nose (estimating 450 pounds), which hopefully brings it close to 50:50 weight balance, front to rear
- 4th gen LS1 rear discs
- C6 Z51 front brakes + 6 pot Wilwood Calipers
