Popping noise at low speeds
I'm getting popping/binding noises at low speeds from the front of the vehicle (from best I can tell, only the front left), mainly when shifting the load; for example backing into a parking spot and turning. It is also present though when I am parked and turn the steering wheel lock to lock. From what I've gathered so far the most likely cause is a bad upper shock mount/isolator.. I had konis and stranos installed about 2 yrs ago and reused the stock mounts and isolators.. (I've seen the terrible pictures of the mounts and isolators due to rust.)
It sounds pretty bad is only getting worse; however the one thing I dont understand is that when its raining out, the noise is gone. I'm not sure if this is just cause whatever is binding/grinding is getting lubed from the rain? Any other ideas on what it could be before I take apart the shock/spring assembly?
Yeah I'm not sure the best way to describe it, but it sounds a little worse than a tapping. Granted it has gotten worse over time, so maybe a few weeks ago it was just a tapping noise.
Thanks.. Ive been too busy with work lately to get around to this still, but I'll check this out this weekend hopefully. I did notice the other week the bushing did look worn, but I didnt have a chance to compare it to the passenger side to see if it was just my imagination.
I'm still open to any other suggestions like tie rods, etc.
I was skeptical at first that that would fix the problem because it sounded terrible before, but (knock on wood) all the popping is gone. I love being able to pul in my garage now without cringing.
SO glad to have it gone! Thanks for the help! If you getting popping sounds like I described above, CHECK THE LOWER CONTROL ARM.
