BMR/Koni Shock Value Sale
Old 04-02-2013, 09:19 AM
  #181
8t8iroc's Avatar
Looks awesome! Thanks for all the before and after shots
Old 04-02-2013, 03:38 PM
  #182
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Originally Posted by FirehawkNS
Pictures of the install and before after.
https://ls1tech.com/forums/suspensio...r-up-some.html
Unlike Chris SS I was raising the car up instead of dropping it, so this will be an example of that.
I can't wait to see a photoshoot of your car after! Thanks for sharing and taking the time to do this for LS1tech!
- Kevin
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 04-02-2013, 03:42 PM
  #183
BMR Tech2's Avatar
Thanks for the pics. The springs sometimes take a bit to settle in, but it's common for the rears to be slightly different so make sure the pigtails are turned the same direction. Something as minimal as this can impact ride height as much as .25-inches or more.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 04-02-2013, 03:54 PM
  #184
BMR Tech2's Avatar
Originally Posted by BDsSlowbird
Got the rear end done today. Shocks, springs, bump stops, control arm bushings, and spring insulators all new. Much to my surprise the rear is sitting about .25" higher than the old SLP Bilstein set up. I knew that after 100k the rear was sagging a little bit, but good lord. I cant wait to get the fronts done. I also picked up new bushings, balljoints, insulators, and strut mounts. Gotta love new parts. Now the sway bars look neglected. They will be next. Thanks again to Kevin and team BMR!
It's not uncommon for factory springs to sag quite a bit. And, with the SLP springs being manufactured by Eibach, it's no surprise when they sag exponentially.
Check to make sure the pigtails on the springs are facing the same direction because they can impact ride height, believe it or not. It might be enough to get it fixed. If you're still having trouble with just the rears, swap the springs side-to-side and measure the change. If the discrepancy follows the springs, give me a call. :-)
- Kevin
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 04-02-2013, 04:15 PM
  #185
FirehawkNS's Avatar
- Kevin
Me either! Getting her aligned tomorrow I hope. If I don't spend all day at the local auto fair Saturday I hope to have a photog day to have an excuse to drive around.
When I first dropped her I could get 3 fingers easily in the front. Took me a week to get back to her to figure out some other stuff and it had settled to the two fingers you see. I hope that's where she ends up.
The rears will be higher by design. I went a step farther from the heater hose mode people used to suggest back with the old springs to try to raise the car. I took the rear isolators off of a fox body mustang a buddy had around, with some work it sits perfect on the perch of the axle and the spring sits on top, raising it about 1/4 of an inch.
Old 04-03-2013, 11:28 AM
  #186
BMR Tech2's Avatar
I commend your dedication to get your car to sit precisely the way you would like. Look forward to seeing the pictures too!
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 04-05-2013, 09:44 AM
  #187
FirehawkNS's Avatar
Thanks. I can't say doing that hurt my handling, but I wasn't as concerned about that. Just wanted a nice stance.
For people doing this, and I will say there is no guarentee that I follwed BMR directions exactly right, but I felt it was a little hard for what I was looking for. So I adjusted it two sweeps softer. This gave me a drastic difference, although a tad too soft, too much drop in the front when doing quick jerky turns back and forth. I dialed it in one sweep back (so one sweep softer then BMR directions) and it feels about perfect in the front for me. Of course this is all subjective and I am getting old so I wanted a little bit of a softer ride.
I still have to adjust the back a little...now wishing I would have spent the extra $100 for the on car adjustable rear. It is awesome how easy it is to adjust these. I can easily go harder for some mountain driving, softer for tooling around town.
If someone got the one car adjustable rears and want to trade + some cash let me know.
Old 04-05-2013, 12:29 PM
  #188
BDsSlowbird's Avatar
- Kevin
Kevin,
No worries on the ride height. I haven't measured side to side but the car sits fine. I noticed that when I dropped the car I had about .25" clearance between the muffler and the floor jack. With the Bilsteins the jack was jammed up against the muffler. The lower terminating end of the springs are both facing the front of the car just as the SLP/Eibach springs were. I made sure to note that and take pics for reference. Keep in mind I also put new insulators on the tops of the springs and ditched the old ones. I doubt the old ones compressed much but it could be a factor.
As for driving impressions, I still don't have the fronts done yet but the rear end feels a lot tighter now, much improved. I'm very happy with the results so far. I'm running 2 sweeps on the rears. I also started putting together some work instructions that may help others for anyone that is interested. Once I get them finished I will post a link.
Old 04-05-2013, 12:32 PM
  #189
Great job on the install and cleanup! I think I am now destined to paint my control arms and knuckles. I'm in the process of painting my calipers and brackets so why not. What kind of paint did you use on them?
Old 04-05-2013, 06:05 PM
  #190
FirehawkNS's Avatar
I used Rust-Oleum Professional Series rattle can from Lowes. I then took some Rust-oleum Clear coat as it lays a little tacky and I clear everything.
I had to wire brush and chip away at some rust to help have a clean surface.
Old 04-09-2013, 06:58 PM
  #191
blue91z's Avatar
Just put in my order! Thanks BMR!
Old 04-10-2013, 10:08 AM
  #192
BMR Tech2's Avatar
Badass! Thanks! Your order has been processed and we should be mailing them out today.
These are still in stock!!!!
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 04-10-2013, 03:03 PM
  #193
50d newbe's Avatar
WOOOT! Just ordered mine with a adjustable panhard bar!! Thanks Kevin for answering all my questions!!!!
Old 04-10-2013, 03:46 PM
  #194
BMR Tech2's Avatar
Not a problem man! Thanks for choosing us.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 04-10-2013, 05:23 PM
  #195
8t8iroc's Avatar
Man I want to be too! Come on payday
Old 04-10-2013, 10:56 PM
  #196
8t8iroc's Avatar
Okay credit card decided to give me an increase in credit, so I just placed my order!
Old 04-11-2013, 01:10 AM
  #197
ggino85's Avatar
how much would shipping cost to 95204.
Old 04-11-2013, 01:42 AM
  #198
Zlow28's Avatar
they have an estimated shipping price calculator on their website. I got quoted 90 bucks shipped to socal. Im guessing your price shouldnt be that different. However im wondering if the calculator is accurate??
Old 04-11-2013, 09:34 AM
  #199
8t8iroc's Avatar
It gave me different shipping options once I entered my address and zip code. I figure to determine both distance and if the address is residential or commercial. Shipping was just under $90, $84 and some change. - for ground delivery that is the basic shipping option.
Old 04-11-2013, 10:51 AM
  #200
BMR Tech2's Avatar
Our shipping calculator is directly linked to UPS, so it's accurate. However, I am not a fan of the ambiguity each shipping company has to particular zip codes with fuel surcharges and stuff. Unfortunately, that kinda stuff is out of my hands. :-/
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Quick Reply: BMR/Koni Shock Value Sale
