LCA recommendation
Old Dec 4, 2013 | 11:24 AM
ragtopz28's Avatar
Default LCA recommendation
Looking for a quiet ADJUSTABLE LCA. The ones I have now are noisy, jarring, rattling (people think my car is falling apart). I have called the maker (not saying who's at this point) and I'm getting the 'never heard that before and we'll take em back with 20% restocking fee (+my shipping cost).
They are brand new as were supposed to be quiet. There is a thread in this section, mine, titled "reward offered" if you want to know the brand. First hand experience please not hear say.
Thanks
Old Dec 4, 2013 | 01:30 PM
smitty2919's Avatar
I don't feel like looking for the thread for the brand because brand is irrelevant.
What kind of LCA's do you have?
bushing/bushing?
bushing/heim?
heim/heim?
A heim joint in any suspension part will add noise. Just depends on how much you are willing to put up with.
Old Dec 4, 2013 | 02:23 PM
ragtopz28's Avatar
Poly on body/del-sphere rod on axle.https://ls1tech.com/forums/attachmen...1&d=1386189183
Old Dec 4, 2013 | 02:50 PM
Zlow28's Avatar
i just ordered adjustable LCAs with rubber bushings on both ends. I think its the best setup if you want quiet and less vibrations.
Old Dec 4, 2013 | 03:05 PM
smitty2919's Avatar
Maybe so for sound and vibration, but I would doubt it for performance.
I'm tempted to go to heim joints on both ends to allow maximum ability to NOT bind.
ragtopz28's Avatar
^^Thanks^^(a little pre-firsthand but I'll take it)
Please let me know how they ride. Thank,
Old Dec 4, 2013 | 03:07 PM
ragtopz28's Avatar
I just sold some aluminum rod/rod (they were worse). Maybe I should have keep them for track use and rolled around on the stockers.
Old Dec 4, 2013 | 03:23 PM
demonspeed's Avatar
It's not mine! woo hoo!
"Good, fast, or cheap -- choose two"
Old Dec 4, 2013 | 03:25 PM
smitty2919's Avatar
Are you saying because poly ended LCA's cost more they are "better"?
Old Dec 4, 2013 | 03:34 PM
demonspeed's Avatar
That was to be taken in the context that one can't expect to have OE-like NVH while also expecting a performance advantage.
I never had a problem with the poly/poly UMI's on my old 2000 SS; my UMI poly/rod LCA's on my current 2002 SS are quiet and ride just fine for me. This sort of stuff usually ends up being subjective.
Old Dec 4, 2013 | 03:42 PM
smitty2919's Avatar
I would agree with the subjective thing. Depends on how the car is used. If it's a DD, then go poly, if it's a track/weekend warrior then go full heim.
Or OP like you mentioned, go full heim for the track and put in stockers for street duty.
Old Dec 4, 2013 | 04:00 PM
Zlow28's Avatar
OP didnt mention anything about performance. He emphasized on "quiet."
Old Dec 5, 2013 | 09:05 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
It seems like there are many different feeling between what someone says is good, bad, or indifferent on this subject matter, but there are some simple facts that need to be kept in mind what selecting LCA and bushing type.
There WILL be more noise transfer with any other bushing/joint than oem rubber.
Poly bushings bind the suspension worse than any other setup.
IMHO... the "johnny joint" bushings are overrated and overpriced compared to the correct heim joint for the application.
Heim joints are not all created equal. Most manufactures are using cheap plastic injected body style joints. This style is as hard operating as a metal/metal joint, and quickly wears which causes vibrations, popping noises, and poor handling. MWC uses a high quality permanently lubricated Teflon lined that isolates the metal-to-metal contact and absorbs a lot of the harshness commonly associated with heim jointed type LCAs. You will never get a better performing suspension link from any other connection than a good quality heim joint.
Old Dec 5, 2013 | 01:40 PM
smitty2919's Avatar
Then hell, put stock ones back on and be done with it.
Old Dec 5, 2013 | 01:45 PM
ragtopz28's Avatar
Originally Posted by ssvert99;17867358 MWC uses a high quality permanently lubricated Teflon lined that isolates the metal-to-metal contact and absorbs a lot of the harshness commonly associated with heim jointed type LCAs. You will [B
never[/B] get a better performing suspension link from any other connection than a good quality heim joint.
Let me try em then...if they don't sound like a midget lying under my car tapping-with-a-hammer-as-fast-as-he-can...I'd buy them.
Old Dec 5, 2013 | 01:48 PM
ragtopz28's Avatar
Original post said I need adjustable (and the stock are on now)
Old Dec 5, 2013 | 03:01 PM
Zlow28's Avatar
Old Dec 6, 2013 | 12:00 PM
Founders Performance's Avatar
If you are mainly street use with light track use I would recommend the 3 piece poly-joint control arms. They are on car adjustable and use a bushing design with a hard inner poly ball and very soft outer cups to allow the suspension to articulate like the factory arms do. The only purpose of the out bushings is to hold the ball in place.
Old Dec 6, 2013 | 12:16 PM
ragtopz28's Avatar
^^Thanks, I spoke to ya'll yesterday on the phone about these...no banging on light bumps huh?
Old Dec 6, 2013 | 03:29 PM
1 FMF's Avatar
who has adjustable lower control arms with oem style rubber bushings on each end ?
