Front Monroe strut nightmare
Old 06-17-2014, 03:01 PM
BD3511's Avatar
Originally Posted by Flaring Afro
Why are you buying everything at summit? WS6Store has Bilsteins cheaper than KYBs. I've never heard of anyone enjoying the ride with KYBs and lowering springs, some just say it's "ok" and can tolerate it.
Summit price matches any Web site pretty much. Plus I enjoy the 40 min drive to there retail store it's fun out there and my daughter has a blast.
Old 06-17-2014, 05:57 PM
Wheelman916's Avatar
Originally Posted by BD3511
I want to try them out because I don't beat the crap out of my car. But at the same time credit cards are meant to be used lol
Just try out the KYBs. Set them on level 2... Drive the car for a while and see how you like them. If they are too soft, bump up to 3. Then repeat.
Old 06-17-2014, 06:43 PM
BD3511's Avatar
Done with the lower again my buddy said stick with the KYB AGX handled nice I'm pleased
Old 06-17-2014, 06:47 PM
nascarnate326's Avatar
I have KYB's and love them.
Old 06-18-2014, 12:21 PM
BD3511's Avatar
Well now that this is all done. Seems like the upgrades need to keep continuing. Going to have to pick up an adjustable panhard bar, and an adjustable torque arm as well relocation brackets. My current panhard bar is a UMI performance one but non adjustable. And the relocation will help even out the rear suspension. Called BMR this morning and they gave me a run down of what would help with any kind of rear noise. He described it as pinion noise.
Old 06-18-2014, 11:57 PM
BD3511's Avatar
Anyone know much about noises from lowering ? If the pinion angle is off will I get rear end howling ?
Old 06-20-2014, 02:02 AM
chrysler kid's Avatar
No but it will magnify it. Change your diff fluid and report back.
Pinion angle is usually only a product of an aftermarket adjustable torque arm. Stock torque arm will not change your pinion angle enough after lowering to cause ill effects
Old 06-20-2014, 09:31 AM
BD3511's Avatar
Well the dealership get's it monday. The pinion seal they put on 2 months ago is leaking. So they are going to put a new seal in and change the fluid. But I thought maybe that howling could be pinion angle or maybe I need an adjustable panhard bar because of off centering ?
Old 06-20-2014, 11:21 AM
SparkyJJO's Avatar
Panhard won't make the rear howl.
Old 06-20-2014, 07:41 PM
BD3511's Avatar
Thought not having an adjustabe panhard bar could cause off centering of the rear end if lowered
Old 06-21-2014, 11:33 AM
SparkyJJO's Avatar
Yes, but only in relation to the body. It won't make the gears howl.
Old 06-21-2014, 11:53 AM
  #32
BD3511's Avatar
Hmmm wonder what's causing the annoying Howl noise.
Old 06-23-2014, 12:36 PM
  #33
SSCamaro99_3's Avatar
If they replaced the pinion seal and did not get the pinion nut back on at exactly the right load, you are burning up your pinion bearing. Ask me how I know Doing them that way has a certain amount of risk. I played it that way to save money and got a few months before it went. The age of these cars doesn't help. I bet you crush sleeve is weak.
Time to save for a rebuild. Has to come apart to chnage the bearing. Mine was so ate up the guy doing the rebuild thought my differential was trash it was so hard to turn over.
Old 06-23-2014, 04:26 PM
  #34
BD3511's Avatar
Got back from the shop today. I have cracked some of the teeth on the ring and pinion I guess. Which I'm sure was caused by a dealership F up. Needless to say under there warranty which they just out of the blue up and changed. They told me to pound salt and they serviced this rear end in april and it's my fault. But clunking and the pinion seal was checked and supposed to be fixed in april. Needless to say things got loud I made a few comments and they changed my fluid and I howled my car 52 miles back home. Not fun at all. I swear with this car if it's not one things it's another. 2 grand plus now on a moser ?? my god!
Old 06-23-2014, 04:36 PM
  #35
Super Hulk Smash
JakeFusion's Avatar
And 2K is the Spool, barebones stuff.
The Strange S60 is like $2400 shipped from CRP. It'll hold up better than a 12-bolt and is an easy bolt-in. For an M6, it would be S60 or 9" all day. But none of the 9" stuff is as affordable as the S60.
Old 06-23-2014, 05:45 PM
  #36
BD3511's Avatar
I've priced out a few rear ends. Honestly sinking 2400.00 right now into this car right now is just out of my range. I'm probably going to just pick up a used 10 bolt to get me by and just pick up a beefy rear end this winter. Just had to happen right at the front of summer. Sucks
Old 06-23-2014, 06:03 PM
  #37
BD3511's Avatar
But I'm wondering. Car shifts fine, grabs, pulls, takes off. The noise since getting the suspension correct has gotten louder. Even at low speeds it's now loud. Could that just be a cheap in the gears ? or could I have a bad bearing
Old 06-23-2014, 08:16 PM
  #38
SparkyJJO's Avatar
Dunno but if it is making a racket it's gonna blow sooner or later.
Old 06-23-2014, 08:23 PM
  #39
springer_4's Avatar
Two things: First I'm going with the BMR'S and Monroe's can't afford anything else right now, 2nd if you need a rearend we have one at the shop sitting around. It was taken from a 99 TA 6Speed, so it's a 3:42. Shoot me a PM if you're interested.
Located in Toledo right of the turnpike
Old 06-23-2014, 08:50 PM
  #40
Daniel Richards's Avatar
if you can't afford better then WAIT, monroes aren't very good at stock height to start with, if you go lowered it's gonna suck *** and once you look at the total cost for all 4 your not much cheaper then a set of Bilsteins from WS6store.
Quick Reply: Front Monroe strut nightmare
