Alignment nightmare!! Need Help Please.
Before L R
Camber:-0.3 1.0
Caster: 5.3 5.7
Toe: -0.75 -0.78
After L R
Camber:-0.2 0.1
Caster: 4.6 4.9
Toe: 0.03 0.03
Fast forward to February 2014 only approximately 2,000 miles later steering wheel is slightly off center to the left and vehicle pulls to the right. I'm now living 100 or so miles away from Big Brand Tire so I take it into Firestone to get the alignment done and I am out in an hour. Steering wheel straight vehicle tracks straight.
June 2014 steering wheel has slowly become off-center to the left again and vehicle pulls to the right. I had to make a quick stop, full brake application. After the stop steering wheel is severely to the left and vehicle pulls like crazy to the right. I take it back into firestone still under warranty, only 1,000 miles have passed since February, they adjust the toe which was -1.3 or something extreme on both left and right. Caster and Camber are off as well. They adjust the toe to zero, but tell me they cannot adjust caster or camber because they don't have the correct tool. The steering wheel is now better and only slightly off center and vehicle still pulls to the right. They refund my money and tell me to try a dealership.
I took it into the dealer today for an alignment and the guy calls me an hour later. He says they can't perform the alignment due to the vehicle being lowered on aftermarket suspension and having "worn out suspension components." He quotes me $110 to give the vehicle an "inspection" and tell me which components needed replacement. He calls back and says they need to replace the struts and springs back to stock and a "torn" strut mount on the passenger side before they can do a proper alignment and get it to factory specs. I said no thanks and requested they do an alignment and get it as close as they can. He said the manager wouldn't let them do it because it wouldn't come out right. I pay them for the "inspection" and take my vehicle. I go to a pep boys and they stick it on the rack, they tell me they don't have the tool to correct the caster either. They tell me to take it to a dealer...No charge.
Now I'm sitting here wondering what could make the toe go so far out of spec so quickly, trying to find a place that can correct the caster and camber, and pissed off. Any ideas?
Any good align tech can adjust the caster/camber with a pull strap/big screw driver, the align is easy to do without the " tool"
Go to several differant shops and talk to the tech face to face ask if they can do best can do with lowered car , you may need sone parts replaced but I dought rack is gone that guick ( I am lowered 1 3/4 to 2 " around and I can get Very close to OE specs, drive / wear great )
Good luck, Johnny
PS you may have a tire shifting a belt, try crossing the two front tires Side to Side for a short drive ( this will not hurt the tire for a short drive) if this does not help driving then cross the rear for a short drive, Have the alignment corrected First
Johnny
If so, turn the wheel all the way to the left(to lock) as hard as you can, drive the car....did the wheel go back straight?
If so the rack bushing is bad, mine did this and the steel sleeve was not in the bushing. Only one bushing in a LS car, on the passenger side.
If you changed racks and did not check for the steel sleeve in the bushing it probably isn't there.
