rear wheel sticking out
Ya I have a 99 camaro ss I noticed the wheel is sticking out slightly on the passenger rear I put in a new non adjustable bmr panhard bar and lower control arms the old panhard bar looked slightly twisted I got it that way what can I do to fix this? Should I just order an adjustable panhard bar?
Adjustable bars are designed to correct that exact offset. When you change your vehicle's ride-height the axle will follow the arc of the panhard bar, therefore being offset at static height. Adjustable bar can be shortened/lengthened to the correct length for axle centering. Hope that helps!
LS1Tech Premium Sponsor
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
http://www.fays2.net/
Most likely overkill unless you race, but it's the best rear axle centering device.
But just get an adjustable PHB and be done with it. I took my adj. PHB off for a watts link but I also autocross.
What link?
