Shock Tower Brace
Old Sep 18, 2014 | 07:36 AM
LS3 Stroker's Avatar
Default Shock Tower Brace
Which one do I need to clear my LSx 102 intake for a 2002 TA? I purchased a used one and it hits the intake....not sure what brand it is....maybe a UMI or Spohn.
Thanks............
Old Sep 18, 2014 | 08:05 AM
UMI Tech's Avatar
Hey LS3. When we're talking to customers we always decline on 102 intakes. There is potential to only have 1/4" or so clearance between the intake and the hood. I'm not sure anyone makes a 2-point that thin. You could try the silly putty (or play-doh) test to verify the clearance.
ramey
Old Sep 18, 2014 | 08:11 AM
ramey
Thanks for your reply! Yeah I just raised the hood and set the brace in there without removing the mounting nuts and it was already laying on the intake. Well I guess that's what I get for not doing my homework/research first!
Old Sep 18, 2014 | 04:17 PM
jimmyblue's Avatar
Moderator
The Hotchkiss STB is probably the thinnest out there
(uses a pair of ~ 1/2" tubes instead of one 1") and the
mounting "feet" are separate with cross-bolts, look
like a trivial bit of welding to add an extension that puts
the crossbar clear of the manifold (clearance from there
to hood, I couldn't say).
Old Sep 19, 2014 | 05:42 AM
Just looked it up and you might be on to something. Seeing how it sits back farther should give it a little more clearance between intake and brace and brace to hood. Especially since its 1/2" instead of 1" tubing. Before I purchase I will do a little more research this time!!!
Old Sep 19, 2014 | 09:09 AM
JakeFusion's Avatar
Super Hulk Smash
I think the Founders STB may fit. I've seen pics of it on cars with the FAST 102. But it's a single tube, so it probably doesn't actually fit.
Old Sep 19, 2014 | 01:07 PM
Founders Performance's Avatar
Sorry but our brace does not fit the 102 intakes.
Old Sep 19, 2014 | 01:33 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
To our knowledge, there isn't an STB on the market that will positively clear a 102. We have had hit-and miss success with the 92's but no successful installs that I know of with a 102
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Sep 19, 2014 | 01:42 PM
Thanks for confirming!
Old Sep 19, 2014 | 01:43 PM
Thanks for confirming also!
