Which Founders PHB?
http://www.foundersperformance.com/1...poly-bushings/
and
http://www.foundersperformance.com/p...-Bushings.html
The obvious difference seems to be where you make adjustments, but what's the advantage of one over the other?
Thanks
Single adjustable IMO would be enough for most people, more than likely including you too. Basically what it does is center the rear axle in respect with the rear tires jutting out from the left or right side, thus making one tire stick out further than the other making it look goofy. Adjustability in the panhard bar fixes this. Keep in mind that this should only happen if you are on lowering springs.
The one that is adjustable on both sides would accomplish the same task as the single adjustable one... The more I think about this the more I believe the bottom one you listed is actually off-car adjustable, this is from looking at the pictures only, maybe the pictures don't resemble the actual product though. Need someone else to chime in here to back me up here if I'm right or wrong.
Running big tires on lowering springs also may have one tire rub against the car itself and an adjustable panhard bar can recenter the axle and help keep the tires the same width from the car rather than one closer to the frame of the car than the other.
http://umiperformance.com/catalog/in...roducts_id=355
The roto-joint allows for greater articulation and along the x and y axis, so it provides maximum movement without bind with the rearend. This is a good feature to have if you ever mess with the pinion angle with an adjustable torque arm or just want the rearend to have the ability to rotate under the car without bind.
Eventually I want to get a watts link but this was a good way to get the axle centered up properly without breaking the bank until I do that.
The panhard rod doesn't need to articulate like the lower control arms so they don't need those other bushings. If you change your pinion angle you can simply loosen the jam nuts and allow the bushing ends to re-center to the new pinion angle and then tighten them back up to adjust for the pinion angle change. Panhard rods are in tension and compression only.
Straight from the source... thanks again!
