Upper Control Arm...oops
Old Jan 2, 2015 | 04:44 PM
1quickTransAm's Avatar
Default Upper Control Arm...oops
I am replacing all my bushings and when pressing the old bushing out of the front upper control arm, the wall bent in like shown above. Should I have put a spacer of some sort in Btwn the walls to hold the spacing? I am guessing there is a special tool for that?
Do you think I can just bend it back or am I F*ed and need a new one?
Old Jan 2, 2015 | 05:19 PM
Sickness7's Avatar
How did you manage that. I can't think of the name of it but there is a type of clamp you can insert inside and turn to expand it. As long as the material doesn't weaken when you do so.
Old Jan 2, 2015 | 07:19 PM
I was using an arbor press with ball joint press adapters and the one wall bent with the bushing housing rather than letting it slide. On the other arms I have been sticking a spacer in to stop it from crushing which was worked well so I'll do the same when pressing the new bushings in.
Old Jan 3, 2015 | 01:20 AM
sleepinghawk's Avatar
If it was me, I would just replace it since they don't cost much anyway. I just priced 1 complete with ball-joint and bushings for less than $40. Add shipping and mine is still under $50. Or you can bend it back and.........
Old Jan 3, 2015 | 08:13 AM
Where did you find one for that price?
Old Jan 3, 2015 | 10:34 PM
I been replacing suspension parts for my hawk and my 95 lincoln over the past 3 months and I have saved alot with them. They had everything for my lincoln and shipping was fast.PM sent
Old Jan 4, 2015 | 12:13 AM
79chevy39.5's's Avatar
still no location where your getting from
Old Jan 4, 2015 | 10:12 AM
Fry_'s Avatar
I'd bet RockAuto.
Old Jan 4, 2015 | 10:34 AM
Originally Posted by Fry_
I'd bet RockAuto.
Old Jan 4, 2015 | 11:02 AM
N20zuki's Avatar
Yea your suppose to put something in the gap when using a press. You can try to bend it back into shape and install bushings. Its common this happens as shops don't use something between the gap in the control arm, Its only made of stamp steel so its pliable without the bushing body to stiffen it.
Old Jan 5, 2015 | 07:55 AM
mab6680's Avatar
just ordered the right and left side for my 97 complete with bushings and ball joints for 40 bucks a piece from rockauto
Old Jan 5, 2015 | 04:25 PM
leadfoot4's Avatar
To the OP, just bend it back, you'll be fine......
Old Jan 8, 2015 | 09:50 PM
^ that's what I ended up doing. Seems fine enough.
Old Mar 19, 2016 | 04:47 PM
Darth Cypher's Avatar
I ran into this issues as well when I pressed out the old bushings on my upper control arms. I put a nut in the gap and it held for the most part but there is still some deformation. I'll try to bend it back but there is no way it will be perfect. Will this cause an issue? I know this thread is over a year old but if the OP sees this, were there any issues since you bent it back?
Old Mar 20, 2016 | 12:59 PM
klinznilk's Avatar
I have my old factory ones that i just took off if need be. ONly 67K miles on them
Old Mar 20, 2016 | 01:12 PM
joeformula's Avatar
Bend it back you'll be fine. The only way it would have been "iffy" is if the metal bent passed a point where it was stretched.
Old Mar 20, 2016 | 01:31 PM
The bends are not as bad as the pics in the OP. Also, there were slight bends on the arm everywhere. I am the original owner and this is the first time every changing the bushing or tearing down the suspension. I guess these arms were not all that perfect to begin with. I'm guessing these arms see a little bending at manufacture? Anyhow, thanks for the replies. I'll just bend back as best as I can, knock the rust off, paint and then proceed with the project.
