Torque arm bushing
Old Dec 20, 2015 | 02:22 AM
bent1's Avatar
Default Torque arm bushing
I need to replace my torque arm bushing. I Have an adjustable BMR torque arm with the BMR relocation mount. Does the bushing have to be a BMR bushing and is there only one type of material for the bushing? Ive been looking at the BMR website and have gone through the first 21 pages under the search "bushing" and no listing. Also tried under 98-02 fbody with no results. Thanks for any help.
Old Dec 20, 2015 | 06:00 AM
RedLineWS6's Avatar
http://www.summitracing.com/parts/bm...61oaAqrS8P8HAQ
Old Dec 20, 2015 | 08:02 AM
01ssreda4's Avatar
You need the bushing with the circle hole in the center. Any brand should work fine.
Old Dec 21, 2015 | 12:34 AM
bent1's Avatar
Thank You
Old Dec 21, 2015 | 10:16 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Give us a call and I can get you taken care of. We don't list a lot of our replacement parts on the website due to us having so many. The number here to the shop is (813)986-9302.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Dec 21, 2015 | 04:37 PM
dailydriver's Avatar
Does your regular, long, stock trans mounted torque arm's bushing have the same size diameter hole in it as the old, long gone Random Tech TA (which I have )??
(WHAT is the diameter of your TA's front single tube where it goes into the bushing???)
I got a UMI bushing, but the hole is at least 1/8" too large for the RT arm's front tube.
Old Dec 22, 2015 | 07:18 AM
UMI Sales's Avatar
Those bushings are generally a standard size but i have had a few instances with some aftermarket torque arms that are built differently whether it be different size diameter tubing or the torque arm being shorter that create a problem unless you use a specific bushing.
Sounds like you need a bushing specific to that torque arm.
Craig
Old Dec 22, 2015 | 08:45 AM
BMR Sales2's Avatar
As long as your Random Technology torque arm uses 1.25" O.D. tubing where it slides through the bushing our BMR torque arm bushing will work for you.
I am almost positive that UMI uses the same size O.D. tubing as us so more than likely our bushing will not work for you. Measure the O.D. of the tubing on your Random Technology torque arm and let us know what it is.
__________________
Glenn ***
Sales Tech
813.986.9302
