F body ABS delete
Who's done an ABS delete on an f body? Considering it because its probably going to cost more to fix whatever is wrong with my abs than to just delete the whole system. Does it stop any better? Driven in the rain? Just want some feedback. Thanks.
I did mine 2yrs ago... hands down the best mod I've done to date. I went the extra mile n cut out EVERY single wire related. Keeping car 4 ever, I hate abs to begin with. Contact Steve & SJM Manufacturing for the correct set up.
Just seems like a really odd thing to say.
Track only car then yeah I can see deleting it, especially since it's more money to keep it when going to an aftermarket rear end.
It only weighs 12 lbs the module itself, hardly worth the time and effort as a weight reduction mod.
And as far as the abs light/fault code coming on with a bigger than stock wheel, you should be flashing in the "new" tire height into the tune anyway to correct the speedometer which will also fix any "abs" issue you might have.
There, is that dumbed down enough for you
Ive been pleased so far. I did it for a million reasons, space under the hood, ease of bleeding the brakes, weight reduction, appearance, one less thing to repair, can run different height tires etc. Can I give you some advice? Please go panic stop your car without abs, one to make sure its adjusted right and two youll know what to expect when that day comes. You can be smart without abs, drive more carefully in the rain especially when your tires are more likely to lock up, dont follow as close.
It actually brakes worse, if you are street driving you have more of a chance at wrecking.
![Mullet](https://ls1tech.com/forums/images/smilies/mullet.gif)
I have no need to slam on my brakes and learn to slide properly, I have abs.
So you run diffrent tire heights and don't adjust it in the PCM? Why? What's the point
Of course you can be smart without abs, you can also learn to drive slicks in the rain and drive blindfolded with one hand if you wanted to learn.
My points were all valid and my opinion backed by facts.
You are just a hothead that train wrecks threads and always have 2 cents to throw in to get your post count up
Half the stuff you post is to belittle people, it's nonsense.
But that's your opinion. Some people like to keep their car working properly.
Oh my fanclub, we must have done this before. Well where do we begin....how about this: ya cant tune out abs genius. Why do you keep blabbering that f-ing non-sense. I tune my own car, yes I adjust for tire size, (which has nothing to do with abs) but then not always, why? Because I run two different size rear tires. Actually I have 10 thats ten wheels for my car if youd like to know. I change em whenever I want and I dont need no stinkin abs making trouble for me. Now, slicks in the rain? No not unless you drive slow enough that it can evacuate water which would like 10 mph. That statement is silly, not "backed by facts" and shows youre reaching or trying to be mr smarty pants. All counter productive. "Learn to slide properly" what does that even mean sir? Do YOU read what you type. When I said learn your car brake aggressively it means try breaking to see if your rears lock up first, what it feels like right before they lock, how to adjust pedal pressure to get them to unlock and start rebraking. It's called actually learning how to drive! I can see this is going over your head, and youll come back and accuse me of being an insensitive ***** and how I derailed the poor guys thread. So for that I apologize to you, and for you not getting it.
The topic brought up by "high n dry" was that race rim/diffrent tires mess with the abs. Which implies you have abs to begin with or else this piece of info wouldn't apply to you.
But can be corrected in the pcm
Panic stopping, aggressive stopping, high chance of lockup in the rain. Yeah these are all situations of sliding and you can't fix that with adjusting pressures, that only fixes the mechanical side of it. There's still a thing called "panicking" and a kid jumping out in front of you which are sometimes out of our hands and the limits of our ability.
It sounds like it's his daily driver so be careful what you tell the guy
I won't insult you, you'll just drag me down to your level and beat me with experience!
Later
I just did the SJM ABS Delete W/Line lock this past weekend. One it looks a hell of a lot better if the Engine is out and you can run the brakelines downwards. Maybe I'm must use to ABS, not sure I'm liking it for the past few days. If I decide to put the ABS back on I'll sell you my whole SJM setup Cheap.
Ls1tech rocks!!! ![Rock](https://ls1tech.com/forums/images/smilies2/rock.gif)
![Headbang](https://ls1tech.com/forums/images/smilies2/headbang.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
OP is this your daily driver? I'm thinking about doing this too but mine isn't a DD. It never sees rain. That's the only thing I would be concerned with is rain unless its really not that bad to adjust. Its when you would have to slam on the brakes in the rain I would question.
![Lhdevil](https://ls1tech.com/forums/images/smilies2/lhdevil.gif)
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
I meant that running different tire sizes don't necessarily mean you lose abs, I run bigger rears vs my fronts and still have abs.
I guess the real answer can get technical on how big you choose to go in the rear vs the front.
But you don't have to get chaotic, I mean we're having a conversation in here.
Try treating people with respect
