Front springs on convertible and coupe the same
I just got my first new trans am 2002 and the front springs were cut to lower the front end. I want to replace them with low mileage springs or new springs at stock height or a little lower ride height. Thanks
I will be changing out the shocks to bilsteins. Not sure how much the spring was cut off but when I run over a pebble the car hits bottom. I want my car to sit up higher then the 25 1/4 in with ws6 wheels and tires that are stock.
I'm lowered on coilovers and set mine to a full inch higher than you. BMR or strano springs would bring you up for sure. Also Moog makes a OEM style replacement that would be good. Bilsteins aren't the "best" shock for a lowered car, but I think the str's are on backorder.
