Just ordered lowering springs.....
I just got the approval from my financial advisor (wife) to buy a set of springs to lower my car. I have heard that I will need to get some lower control arm relocation brackets or I will spin like hell at the track.
Can someone give me the details on the whole truth? Help me understand why I do or don't need them.
I'll chime in, I didnt get the brackets or lower control arms no problems with traction yet. Some people also recommend getting an adj pan hard bar to recenter your rear wheels, no problems with mine either so I didnt get it yet. I did get a 21mm rear sway. As far as shocks I would definitly get the front ones at least, that way you wont have to mess with that again. So if wanna wait on a few things or get them slowly it can be done.
Originally Posted by 99-LS1-SS
What kind of shocks should I get? I can't pay $400 for 2 shocks right now. Would a set of new stock SS shocks be ok?
Good luck!
Shocks-cheap but excellent.
Originally Posted by ChoiceCam00
Do not get the french stock shocks and struts. They are too soft. The KYB AGX is only about 79 for the back and 85 for the front. I had them put on last year and they are awesome. Be advised that if you install lowering springs and KYBs or Konis(which I wanted but couldn't aford it at the time), your ride will be stiff. Really stiff. I have the KYBs agxs and Eibach Sportlines and my 2000 SS is very low. Good luck. Kevin from Las Vegas.
I had BMR springs first, and it did ride pretty firm. If you are on a good highway, they are OK but when you start getting into some rough spots in the road, they are rough. I ended up sending my BMR's back and getting a refund because my car sat very uneven. It was as bad as 3/4 of an inch from side to side. I ended up going with DMS and they ride nearly like stock. When the BMR's were on, you could push down on the front end and hardly be able to bounce the car, my DMS springs are different. Just my 2 cents!
