opinions on necessary rear suspension upgrades
I'd like to know what your guys opinions are on what is necessary and what is a waste of money/time. I have an automatic 02 formula, as of now it just has basic bolt ons (headers, exhaust, lid, tune) I have a founders adjustible panhard bar and relocation kit on it to clear exhaust better and center the rear end for 11" rears. Id like to eventually do heads, cam and a converter and would like the car to be able to crack into the 11s. I've seen some guys with minimal suspension mods run in the 11s and other guys swear by needing an adjustible torque arm, adjustible lower control arms, sway bars (i know not necessary for the drag strip) and pretty much buy the entire BMR catalog. I plan on adding sub frame connectors, but aside from that what is really necessary, and what can i do without..car is standard height now, may lower it a touch but not slammed. Thanks.
pic of the car in case anyones curious
Since every car is a little different your best bet is to have a buddy record your launches, so other can see what the car is doing that can be improved. This would be the best way to buy what is needed and not just follow the path of usual parts. That being said, stock shocks are only better than dirt pile ones at the local auto part store and would be a great place to start.
Aftermarket lower control arms are more rigid than the OEM lower control arms and typically have better bushings(poly) than the rubber OEM bushings. BUT that has nothing to do with the LCA relocation aspect. Relocation changes their working angle to enhance traction.
-shocks and LCA relos to start
-next would be aftermarket LCAs'
LS1Tech Premium Sponsor
They do 2 separate jobs. The control arm just stiffens up the connection between the axle and the chassis. The relocation bracket actually changes the angle of the arm to make changes to your instant center geometry. This is what actually makes the whole suspension work. The relation of the torque arm mounting position and the control arm angle controls how hard the car hits the tire, if it squats or separates. These are essential in correcting geomtery in a lowered car, but also help in a stock height car
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Thanks for the input, I forgot to mention shocks are definitely one of the next orders of business since they are the original garbage with 69k miles on them. As of now I don't think having someone film me launching is going to get me anywhere until I'm making enough power to cause traction issues, BUT I would like to do a few things prior to building the engine at all..so it sound like LCAs and relocaction brackets are a good starting point with good shocks.
A good budget street/STRIP shock is the Viking Warrior.
For a more aggressive approach you can upgrade to various Crusader valvings as well. It really depends on how fast you want to go eventually...
At UMI we can spec the correct damper based on your goals.
ramey
ramey
https://umiperformanceinc.wordpress....o-info-part-2/
Viking has Crusader for road racing, auto-x, drag racing with various hp levels, street rod, etc.
We carry the full line and can custom order any of the valve codes.
The Crusaders tend to add $75 per shock.
I've attached the damping curves for your enjoyment. If you call we can explain what they do and how they differ from the Warrior valving.
ramey
ramey
