94 Z28, how do i make the suspension stiffer on a budget?
hey guys, i made a exhaust system which requires more clearance. i am wondering if there is a cheap/easy way to stiffen up the suspension and maybe get a bit more ride height.
At Advance and/or Autozone
I travel a lot with my Z. Carry a lot of 'stuff' in the back,full size spare,complete tools,spare parts,fluids. Used those spacers for over 10 years. Installation easy,raise rear of car to have rear end hanging and use large channel locks to 'twist' in. They will change the ride,a bit more 'bouncier'.
oh man.. spring spacers... those may come off if you hit a speed bump just right.
it would also dramatically increase the spring rate in the rear as it compresses.
i do not recommend this.
i can't see how this would be safe either.
Moderator
Received 1,836 Likes
I'd maybe start by replacing the soft parts. Just getting fresh bushings under there can dramatically tighten up the ride
I would ask where the problem actually lies before suggesting suspension parts.
What is the exact problem? Exhaust clearance related. Lowering springs would not be the answer to an exhaust clearance issue!
Where is the clearance issue at?
> If it is the exhaust getting hit by the axle under compression, it sounds like the over axle pipe needs adjusted.
> If it is the exhaust hitting the ground, it sounds like the pipe is hanging too low and needs to be tucked up under the car better.
> Other?
Simply raising the car up is just a band-aid.
> Other?
