Adjustable Sway Bars... Anyone using them?
Alright don't buy anything yet, lets go through a checklist.
Are you running the same tire front and rear? Not running some cheapo no traction all season tire in the rear?
You don't have the tire pressure jacked up in the rear right? No more than 30psi all around?
Are your rear shocks set at or near full soft and not full hard?
Are the LCA's poly bushings on both ends? (Poly can stick and bind which can cause oversteer) If so try putting your stock LCAs back on without the relocation brackets and go for a drive and see if you are still getting oversteer like you were before. If that does solve the issue but you still want to run aftermarket LCAs then get roto-joints on each end. If that doesn't solve the issue then put on your stock rear swaybar (which is 19mm) and go back out for a drive and try again, get back to us on here and tell us the results, it should be one of those two I would guess, assuming the check list didn't fix it above.
The problem with adjustable rear swaybars is some might start out at the stiffness you already have right now and only get stiffer with adjustment, which would cause more oversteer. Some may not be like that though, you will have to ask the manufacturer how they compare stiffness-wise with each adjustment. Plus you can run your stock 19mm rear bar for free or find a used stock 21mm rear bar off a 3rd gen for cheap, then the next step up would be roughly what you have now, a 22mm rear bar, and you don't want to go stiffer than that if you are already having oversteer issues.
Do the free stuff first, like if you still have your stock rear swaybar laying around try putting that back on and see how it feels.
However, I want to focus on the fact it's loose on power down. That is pretty typical of a car with a lot of power and not a lot of grip. Anytime you spin the tires, you will get oversteer. It's worst with a stock, weak, limited slip. If the balance of the car is ok mid corner, then a smaller bar will hurt that, and you already state you lack front camber, so I think the issue here is that it's time to look into a better diff, better tires, etc.
Hollow vs solid bar stiffness isn't much because the rate of the bar is from the outside of the bar.
My old road race car I had 12 full sets of springs, wet/Dry for 3 tracks, plus the ones that didn't work..
You can only dial out so much oversteer with tire pressure..
Stiff springs will do as much as a stiff bar to let the rear get loose.
Stiff flex joints(LCA's as noted above) can raise hell...
Are you lifting the inside rear when it lets go? Sometimes if you have too much quick roll it will
plant the outside tire too hard then inside rear lifts and you don't gain as
much traction on the outside as you lost on the inside and around she goes..
How old are the tires and how many times have they been run? (If you've already scuffed the outside edges off ... they may give up early.)
Was the surface prepped by being swept and vacuumed or just swept? (It matters.. )
The Alloy of the bars matters too..
Good luck..
Good luck..
