Car shacking at highee speeds
Ok car is 2000 firebird with a4 has 180000 on it .the car shacks when I drive about 90 and above. I just had an alignment and new tires put on I do not feel the shacking in the steering wheel. What could this possibly be?
The car was shaking before and after I thought it was all because I really need tires and alignment. But the shaking in the steering wheel is gone the rest of the shaking is still there I only feel it when I am about 90mph. If I step on it and start to accelerate I don't feel it only when I am crushing at higher speeds
Maybe don't drive that fast. If there was vibration in the steering wheel and now it is gone... but there is still vibration it could be a bent wheel that was moved from the front to the back. You could rotate the tires and see if it follows the axle. Something rotating is causing the vibration is all that anyone on here will be able to say for certain without more details. Could be the driveshaft, does the vibration go away in neutral... Could be a wheel out of round or bent.
Ya I should slow down its hard I work graveyard and when I go to and from work no one is on the highway. But I guess I should have added the car is lowered from what I can tell the springs were the only thing changed stock panhard and trailing arms
