STB Touching LS6 Manifold
Alright so I've seen issues with the FAST 102 having clearance issues with STBs but never and LS6 intake manifold. I just got my car back together and am running solid motor mounts, so maybe that's the issue because there is no give or worn out rubber to let the engine sag a bit? The STB definitely had at least a finger thickness of clearance to the manifold before the solid mounts went in but now it is sitting directly on the manifold. Did anyone figure out a spacer plate for a STB? I've seen one thread where a guy spaced his up with a bunch of washers but that seems like a terrible idea to me.
Thanks in advance.
Thanks in advance.
Using washers as spacers would defeat the whole purpose, there will be too much deflection in those. You really need a flush surface contact onto the strut towers. The pics on Founders website seems to be very similar to the UMI brace I have, which, with (stock) LS6 intake on my LS1, stock motor mounts (never had motor out), I still get a fingers worth of clearance (about 3/4 inch).
Strano sells a spacer plate with his brake MC brace, which is the UMI mounting plate. Maybe call UMI or Founders to see if they can sell you a raw plate for a few bucks. I bet they could pull 2 from the assembly line and stick em in an envelope or small box for you.
To me it just seems like using washers would put more stress on the bolts and a smaller area of the mounting surface since the plates on the STB is made to sit directly on the strut tower and they distribute the load over a wider area. Although, the STB touching the intake might not even be much of an issue with the solid motor mounts since the engine doesnt really flex separately from the chassis right? I might just be thinking too far into it.
Actually you might be right. If it's just very lightly touching the intake it may be a non issue. If it were me I'd take the car for a a small easy drive and see what happens. At that rate I think you'd be fine, and if so I'd try it again but a little more spirited drive. Basically doing it in small stages and see if it's even an issue at all. Know what I mean?
Yep I hear you, and it would bug me to, but it sounds like youre fine then. Like mentioned above maybe the guys at Founders, BMR, UMI, etc....would have some ideas. I have a buddy who used some extra washers to clear his 102, and to this date he's had no issues, but that's not to say it's the smartest idea lol
