Front Stabilizer Bar Bracket
Old Sep 15, 2018 | 08:32 AM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
Question Front Stabilizer Bar Bracket
Own a 2001 Z28 (Sara) with aftermarket BMR swaybars front and back. My front stock R/H side bracket broke. Has anyone else had this problem on their vehicle?
Thanks in advance.
Old Sep 15, 2018 | 02:12 PM
FormulaJoe's Avatar
I have seen people have issues with them bending/breaking who AutoX and road race. I forgot where to find them, but someone does make a beefier/reinforced bracket.
Old Sep 15, 2018 | 08:33 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Gm 10234622
Old Sep 15, 2018 | 09:41 PM
sjsingle1's Avatar
blaine fab sells a GM bracket with a brace welded in....or you can get a bracket brace from UMI to weld in.....or buy new beefier aftermarket ones ( think UMI bracing on steroids ) from Detroit Speed
Old Sep 16, 2018 | 08:38 AM
SteveC's Avatar
Thank you all for the replies as posted above I found the beefier mounts @ the "Detroit Speed" sight. This vehicle is a garage queen with only 50K original miles, never raced or auto x. Maybe the larger solid BMR bar was too much for the stock bracket to handle.
Stay well and GOD bless.
Old Sep 16, 2018 | 09:59 PM
sjsingle1's Avatar
the BMR bars are larger....but mine is hollow....did they change to solid ?
Old Sep 17, 2018 | 08:28 AM
SteveC's Avatar
Smile
I do not know, I purchased the front and rear bar separately from BMR 17 years ago, I believe it was a solid front and rear bar, they both are extremely heavy.
Old Sep 17, 2018 | 09:15 AM
mikedamageinc's Avatar
A guy local to me has broken his several times autox on completely stock Camaro. But if you dont race it just go to the junkyard and grab a used one.
Old Sep 17, 2018 | 11:32 AM
SteveC's Avatar
I am attributing this bracket breaking to metal fatigue so consequently I am going to replace both brackets
Old Sep 17, 2018 | 02:10 PM
Chrisingermany's Avatar
Was this something that was easily found? Like did you hear popping or something felt weird? I auto-x and road race quite often and as far as I know my brackets are just fine. When UMI came out with the beef up plate, that was the first time I heard about this but it sounds like it may be pretty common.
Old Sep 17, 2018 | 02:40 PM
SteveC's Avatar
Yes it was very easily found I was in for an oil change and was under the vehicle when I noticed that a brace was just hanging down off the sway bar cracked with the other half on the frame of the vehicle. Prior to that the vehicle felt a little unstable going around corners.
Old Sep 17, 2018 | 06:02 PM
LS1121's Avatar
I had one break on the passenger side and replaced it with a OEM GM part. My car is old and parts break, they are not meant to last forever. I also had Poly bushings on for years when it broke. Poly does not give like rubber. I replaced both with MooG rubber bushings when I rebuilt my suspension. I had the maint. guy at work weld my broken one and have it as a spare.
Old Sep 17, 2018 | 08:11 PM
79_T/A's Avatar
Happens all the time, it’s a weak design.
Old Sep 19, 2018 | 07:16 AM
SteveC's Avatar
I went ahead an ordered the Detroit Speed sway bar bracket kit # 031418, this should solve my problem. I too have poly bushings all over the front and rear. The Detroit Speed Engineering Tech told me they are 100% bolt on replacements that come with the attaching hardware, no fabrication, welding or praying needed. They installed them on both a 1998-2002 WS6 and Camaro Z28.
https://www.detroitspeed.com/heavy-d...irebird-031418
Old Sep 19, 2018 | 09:38 AM
The Detroit Speed ones look nice and beefed up. May have to look into this and get a set. I am running Strano sway bars and I believe they came with poly bushings and with 315 tires up front mine are still holding up as far as I know. This may be a piece of mind thing to knock out though.
Old Sep 19, 2018 | 11:57 AM
sjsingle1's Avatar
^^^ I watched your videos ....and surprised you have not bent the bracket yet !!!
Old Oct 4, 2018 | 09:32 AM
SteveC's Avatar
Hello everyone, had the Detroit Speed Brackets installed in Sara (2001 Z28) and as stated @ the Detroit Speed sight, "they ARE 100% bolt on with no modifications needed".
Sara and I are back driving down the highway of life together
GOD bless you all.
