1LE Bushing replacement
Old Apr 10, 2019 | 08:58 PM
PMD Power's Avatar
Default 1LE Bushing replacement
Hi all,
I know the Moog are a prime replacement, however is it possible to press the old out and new in with the ol' "C" clamp press or is this something I'll need a true machine press?
Old Apr 10, 2019 | 09:04 PM
lees02WS6's Avatar
Originally Posted by PMD Power
Hi all,
I have pressed bushings out of front and rear control arms with a washer, a long piece of threaded rod, some nuts and a big damn socket, and piece of wood to keep the arm from collapsing. So no, you don't need a press, it makes things go faster though.
Old Apr 10, 2019 | 09:25 PM
PMD Power's Avatar
Thanks! In the past on other cars I've done similar, good to know the LCA Bushing here is no different!
Old Apr 18, 2019 | 12:33 AM
Kokomastah's Avatar
pay close attention to the piece of wood to keep the arm from collapsing part. i messed up both my rear control arms trying to press new bushings in and out myself because i didnt have something suitable to put inside them to stop this from happening. now im looking for replacements cuz im tired of the poly/rod aftermarket ones.
Old Apr 18, 2019 | 09:22 PM
Spartan7's Avatar
I used Autozone's ball joint press rental tool to do mine. I used a small socket wedged in the arm to keep it from collapsing. It's not fun doing it that way, but it works.
Old Apr 18, 2019 | 11:03 PM
PMD Power's Avatar
I just failed tonight trying to do the bushings with the ball joint tool. I've pretty much given up and will call a machine shop tomorrow lol.
On a side note, is it normal for the OE bushings to say black and pink on them?
Old Apr 20, 2019 | 06:05 AM
Spartan7's Avatar
I just looked at one of the pics I took before I swapped them, and it does indeed say "Black" and "Pink" on the bushing. I never even noticed that.
Old Apr 22, 2019 | 09:50 AM
PMD Power's Avatar
Thanks! I was wondering if I had some sort of aftermarket bushings!
