front strut assembly question
Thanks for answer, so that means the upper mount and lower spring perch are not adjustable at all. Maybe my old springs are too old to re-use since the ends must not line up quite right anymore.
click here
Just a note for anyone installing an engine from underneath: when you're lowering the car / jacking up the engine/kmember assembly to bolt the kmember to the car, don't expect to be able to line up the top strut bolts with the holes in the engine bay, they won't be anywhere close no matter how you try to force it and you'll end up having to take the shocks/struts off and then re-install them.
I need to pull my driver's side out again so I can finish replacing the bushings. I was thinking of trying to bolt the shock in 'backwards' to the lower arm and then I could pull the top away from the fender, rather than trying to work with it in the wheel well where there is no room (with a jack gently supporting the lower arm). Then I could unbolt it and install it normally,and the angle of the bar should be closer.
