Time to lower the camaro opinions needed..
Im going to buy some springs and a set of shocks, what is everyone's favorite? I just want it lowered about an inch, I've heard Eibech's will make the driver side an inch lower than the pass side, does anyone know if that's true? How are the blistein shocks? My goals are to lower the car an inch and for the handling and traction to improve. Thanks in advance.
The springs will not make the drivers side lower than the passengers side (unless one side of your car is really heavy
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Eibach Pro springs and Bilsteins shocks should give you the results you're looking for, you'll also want to get an adjustable panhard rod. When going to lowering springs you need to be carefull of the back spacing of your wheels, stock wheels should be fine but some aftermarket wheels may cause tire rub.
Al
Al
I Lowered My 2000 Ws6 A Year Ago With Konies And Eibech I Dont Drive It Often So Today It Was Time For An Oil Change And I Noticed That The Passenger Side Is Lower So I Switched The Rear Springs Side To Side And It Still The Same So Till Now I Can Not Explaine It But I Will Soon And I Will Let You Know.
OK, like what. I was on page 3 of my search and this was the best thread I could come up with?? Gonna run into some cash this spring and I think lowering will be the next thing for me.
