Traction control kicking in...
either way traction control should still act in the same manner as it always has.
-Stuart
This is true also
BTW, pulling the TCS fuse from under the hood works real well, does not effect the ABS and is free.
It's kinda rare to make it happen but i'm sure i felt that a few times at least in suitations like that while on light throttle.
It's not the rearend posi unit doing that.
There's a motor looking thing in the back of the bosch ABS module.
It appears to be a non serviciable part, just a R&R item.
I would take a defective one apart to see how it works inside
Have you checked out the brake system digram for a ASR/ABS equipped f-body?
The diagrams I researched were specifically for my car. A 99 TA with TCS and manual tranny.
I'm not too familiar with the Camaros. Is ASR what the call traction control?
Right now it's usually the newer, high end cars that get what is called stability control. That is a system which CAN apply brakes to certain calipers to prevent the car from sliding of the road etc... F-bodies do not have this.
I do know for a fact a few new cars comes with adpative cruise control (mercedes comes to mind) that you can set a distance to follow another car in front of you if their speed is slower than your set speed and it applies up to 25% braking if the car in front of you slows down making the distance shorter.
However that won't work well if someone slams the brakes in front of you in your lane out of the blue...
The throttle pushback you are refering to is caused by the TCS motor which is mounted behind the battery.
When TCS activates, it first reduces timing to reduce power. If that is insufficient, the TCS motor will physically close the throttle and you feel it pushing back on the pedal. The automatic cars also have a torque management system to reduce force to the rear wheels, but since I have the M6, I didn't go into detail on how that works.
Your post totaly makes sense I'm just out of my mind right now.
