NEED Help!! Swaybar removale
I'm trying to remove my swaybar, I can't get the end links to come loose. My impact won't even budge them. I have the impact with a 14 mm bolt on the botom, and I'm holing a 13mm wrench on top, not budging. What am I doing wrong??
If they have been on the car awhile they are a pain in the ***. I ended up breaking mine because they where all seized up like yours. I would pick up some new ones and put alot of never seize on them so they come apart next time.
Yeah, if your doing a bar swap just make sure someone local has them in stock so you don't have to go without a bar. Or if your taking it off for good don't worry about it (asuming it's the front).
Yeah, its the front. I'm in the process of swapping trannys and I thought I might try this too. If I don't like it, I'll put it back on. Will it help my 60'?? I cut 1.685 with 4L60 E and 2800 vig. Ill probably be going with a 3200 with the 350 turbo.
