Slot direction
Thanks, pics would help too. I just received my slotted drilled Brembos from Wholesale Direct. Oh, by the way, what caliper paint would you all recommend? Thanks...
That is the standard approach (I think Baer is different, but that's usually correct).
It is a popular misconception that the slots or drillings in a disc determine the direction of rotation. In truth, for an internally vented disc, the geometry of the vanes dictates the direction of rotation. There are three vane types in use:
* Straight
* Pillar vane (comprised of many small posts)
* Curved vane
The first two vane types are non-directional, and can be used on either side of the vehicle. The curved vane disc, however, is directional. A curved vane disc must be installed with the vanes running back from the inside to outside diameters in the direction of rotation. Please see figure. Orienting the disc in the manner creates a centrifugal pump. The rotation of the disc causes air to be pumped from the center of the disc, through the vanes, and out through the outside diameter of the disc. This greatly enhances the disc's ability to dissipate heat.
Additionally, all of Brembo's slotted discs are directional as well, regardless of the vane geometry. The discs should be installed such that the end of the slot nearest the outer edge of the disc contacts the pad first
the vanes are what dictate the direction of the rotor.
slots can be done in both directions (reversed and traditional) and makes no difference whatsoever.... personal preference.
in your case, either way is fine.
I have noticed a lot of people do not follow that methodology
