Relocation Brackets a must?
Old Mar 10, 2005 | 04:07 PM
Gallitin's Avatar
Default Relocation Brackets a must?
To put on LCA's are the relocation brackets a must?
Thanks,
Nathan
Old Mar 10, 2005 | 04:33 PM
smokin' joe 00 ss's Avatar
No they will bolt up to the stock location if you lower your ride you will want to get some.
Old Mar 10, 2005 | 07:18 PM
DrkPhx's Avatar
Thanks,
Nathan
If your car is lowered and you are serious about traction at the track they are.
Old Mar 10, 2005 | 10:31 PM
Ferocity02's Avatar
I am lowered, but not enough to where I need relocation brackets. I have no traction issues.
They are not needed for stock height.
Old Mar 11, 2005 | 03:30 PM
Bill's 02 Z-28 SS's Avatar
Hi Folks
If you have wheel hop, you need the bracket - I plan on getting one because I have severe wheel hop.
Bill
Old Mar 11, 2005 | 03:56 PM
jwastedx's Avatar
They help with wheel hop alot A++ mod to do.
Old Mar 12, 2005 | 08:32 AM
2w0s060's Avatar
Maybe this info will help those that are not quite sure of the purpose of the relocation brackets. I have seen this topic discussed alot and it seems to bring confusion
http://www.umiperformance.com/2010.aspx
Old Mar 14, 2005 | 10:26 PM
joblo1978's Avatar
At stock height you will notice a considerable amount of improved traction and less wheel-hop though. I installed mine before I lowered the car. It's a huge difference, night and day.
Old Mar 16, 2005 | 12:27 AM
LetMeBurnU's Avatar
Im planning to lower my car using eibach pro-kit, right now im running the BMR Lca will i need the relocation brackets?
Will i be able to lower the car without having to use the brackets..?
Old Mar 16, 2005 | 02:05 AM
1 BLOWN V8's Avatar
This is a good question. What is the difference between a bolt in style and a weld in only? Who makes the bolt on ones?
Old Mar 16, 2005 | 09:17 AM
~JOSHUA's Avatar
BMR makes bolt in ones.
Old Mar 16, 2005 | 12:43 PM
RedLT4Mike's Avatar
Yes they are a must!!!
Now go do it NOW!
Old Mar 16, 2005 | 06:38 PM
joblo1978's Avatar
You don't need them to lower the car, they don't affect ride height at all. I installed mine before I lowered and there WAS a noticeable difference in traction. I can't speak for a lowered car without them though. Let me put it this way. Any wheel hop I had before I lowered was totally gone. Going full throttle in first and second gear at high rpms over broken surfaces the *** was completely planted. You can feel the bumps but the tires stay on the ground. It's hard to spin tires now. A very cool and a must mod IMHO and mine are BMR bolt-ins. If you're going to lower, buy Thunder Racings lowering package and some shocks like I did. Do it right.
