Rod-end Question
I have read from quite a few people that the rod-ended LCA's do cause lots of noise, hope this helps.
I've never heard anyone say that their rod ended PHR added noise (unless the rod ends were cheap or worn out).
Also, if the LCA bolts aren't torqued enough, it can make them move around and add noise. Especially if you have SFC's that go around the LCA bolt. You have to tighten the crap out of them to bend the metal ears tight against the bushing spacers.
Moving back to the rubber PHR will make the rear floppy again. Do you want that? Why did you go with rod ended parts in the first place? Just curious as most people are more interested in the performance.
Were the rod ends still tight?
What exactly were they doing, such as tranfering a buzzing or whirring sound, a vibration? How would you describe it?
I'm asking because I will replace my LCA's soon with rod ended ones. I just want to know what to expect.
Thanks.
http://frrax.com/rrforum/index.php?act=ST&f=3&t=3553&
