Spohn Chassis Mount TA Opinions
How does everyone like this torque arm? I will be buying this thinkg here in the next few days. I searched and found whats wrong with it, but nothing about how good it is.
a bunch or people are having problems with it maing a "thump" when shifting? Cant get the pinion angle right....blah blah blah. I have solid engine mounts so a thump is the least of my worries. I am just curious if i the spohn ta will hold up enough and definatley need to know if the floor pan will hold up enough for a 6 speed setup. I would hate to have a ta though the floor
I was going to go with that unit but I've decided to go with the Spohn tranny mount unit in chomemoly. I'm also going to use the Yank transmission mount which relocates the TA bushing off the tranny. No clearance or noise issues and I'm not a regular drag racer...
I got the body mount one. I have no problems with it. I did change the bolt direction that from way it came from spohn. Get the poly mount. I did not like the idea of mounting it to the trans. I am sure GM did it for noise. The part looks good. If you cant adjust it you should not be installing it yourself. I got the digit angle finder from work and measured after I got it together. It was right on. so the one that comes with it works.
That is the same setup I decided to go with.
I have the body mount torque arm....no thumps....pinion angle was easy to get set-up. It held up to my 618 fpt on the chassie dyno and I am still using it with my twin turbo set-up.
i just put one up and i like it sofar
does not make to much noise at all...no thumpin
only problem i see is with the 12 bolt the mount that goes on the rear hits the tunnal a lil bit but not so bad
