How 'bout this setup?
Kenny Brown SFC's
BMR extream TA
BMR Sway Bars
BMR adjustable Panhard
BMR LCA's
Eibach coils. pro or sportline??
Hochkis STB
Relocation brakets?
P.S. I've got Hooker LT's and Off road Y-pipe. I want a low stance but I don't want to drag on the ground. Also, I've got 12xxx miles on the car, should I just replace the shocks now? If so, what kind?
) you can buy instead of the BMRs. I have the BMRs and they are starting to rust.
Otherwise looks good man.
I hve a set of eibach prokit and after some time, yes they get a bit annoyng. The rears are the problem. ITs not THAT bad but they could be a bit tougher (higher rate) for the amount of drop.
The ground control/ eibach set is heights adj all around which is interesting since you are concerned with height as i am....I also have lt's and im really low, more than the advertised value..well ever since the new iron block!!
Anyways, for handling, stay with a regular length torque arm but definitely go aftermarket, better brake balance, hollowed sway bars 35/22mm.
The SFC, STB, panhard, and lca are fine but know that there are some inconsistencies with bmr panhard and that the polybushings can cause somw ill effects on your suspension. I also noticed you didnt mention any shocks or springs....wat are your ideas on those?
good luck.....research as much as you can!!!!!!
