Quick question please
my last trip to the alignment shop was due to inside tire wear. i thought it was a toe issue. turned out to be a tierod issue. both sides had started to get loose.
Are these shops giving you print outs or actual #'s for your toe and camber settings?
The reason I said to take my comments for what thy're worth is because I abuse the outsides autocrossing. I only got 4000 out of my MX's, and that was wearing them down well below street legal.
" " -.82 and now it is +.12
toe was + 3/32 and now it is 0
toe was -1/32 and now it is 0
looks like the tire wear mas mainly due to the toe being off now the toe is zero both sides one side was pos 3/32 and the other was neg 1/32 wtf? Do you guys think that the new camber being slightly positive will take away from handling? Most of my driving is highway miles, but when I am not on the highway I like to drive the backroads really fast. Maybe when I replace the ft tires I will have them dial in slight negative camber again what do you think? Was the toe settings the reason for the inner tire wear and not the neg camber?????????????
