Sway Bar
If you think you need a bigger rear sway bar get a slightly stiffer one. Too stiff will make the rear slide easily in corners. You basically need the front stiff and the rear soft to help put down the power.
Choosing the rear bar will just need to come later, if at all.
I've gone through so many iterations on my suspension it isn't even funny.
I can't believe I have such a hard time getting my car to understeer.
I've got 550lb fronts, 170 rear, Koni SA all around with fronts about halfway and rear all soft. -1* camber, 35 solid front bar and stock 19 rear. 275 nitto RII fronts and 315 Nitto R rears.
You'd think the smaller front tires and big bar would make the front slide first, but it's the rear that will slide under power. It's weird, I wish I had a BIGGER front bar to balance it out.
That's why I say go big up front. 35 sucka!
On a side note, can anyone make a suggestion to help balance my car. Maybe some 600lb front springs, 150 rears, something?
I'll stick to the regular PHR and just switch to relocation brackets and better LCA's and see how things are at that point.
I don't want to hijack the thread.
As for your particular car being loose. You have very different tire on both ends. You have a road race tire on the front, a drag tire on the back. Which one do you think will stick better in the corners? More than a little you are experiencing mis-matched tires I think. I still feel 170 is stiffer than you need, but those springs with a 19mm bar isn't overly stiff at all (I just prefer the 150/21 or hollow 22 combo for tire compliance).
